Tractor Talk Discussion Forum
ferguson 40 hydraulic problem
Neal
02-14-2005 08:04:28
I am working on a ferguson 40 in which the 3 pt. does not stay up and it has little lifting power. I have put in a new lift piston and rings and had the cylinder honed to remove scratches (.003-.004). I had the cylinder honed because a new was not available. I can see oil leaking past the cylinder and it gets worse with the more weight that is added to the 3pt. I am wondering if the cylinder to piston clearance is too much now or if there is a problem with the rings. The face of the ring that touches the cylinder is beveled and I am wondering if the pressure as it is increasing forces the rings to collapse. The rings and piston are aftermarket. Does anyone have any experience with this situation. Any help or ideas would be appreciated.
rod s
02-15-2005 05:35:20
 Re: ferguson 40 hydraulic problem in reply to Neal, 02-14-2005 08:04:28
hey are you sure the rings are on the piston correctly?? I have the shop, and parts manuals for the F40 drop me an email and maybe I can provide more info on the system, are you sure gasket or orings is ok where the lift tube bolts to the top cover regards
rod
