Tractor Talk Discussion Forum
ferguson tractor
bryan86
02-12-2005 19:50:13
how would you find out what year model your tractor is. i just purchased this ferguson tractor. it is a four cylinder gas engine with the distributor on the left side of motor. where can i find serial numbers or something to identify the year.
Jerry/MT
02-13-2005 21:56:24
 Re: ferguson tractor in reply to bryan86, 02-12-2005 19:50:13
One key, visible difference between the TO-30 and the TO-20 is that the -30 has an external oil filter on the right habd side of the engine. The -20 filter is located in the bottom of the oil pan.If the engine data plate is visible, the Continental Z129 engine only went on the TO-30.
Rlach
02-13-2005 11:16:56
 Re: ferguson tractor MORE INFO in reply to bryan86, 02-12-2005 19:50:13
Ferguson 20 and 30
All Ferguson 20 & 30 have 4-speed transmision
TE is for tractor England
TO is for tractor Overseas
Ferguson 20 :
TE-20 : Continental Z120 engine, 120 CID (Oil filler pipe near front of engine close to fan)
TO-20 : Continental Z120 engine, 120 CID (Oil filler pipe near front of engine close to fan)
TEA-20-80 : Standard engine, 113 CID-80 mm bore (Oil filler pipe above starter)
TEA-20-85 : Standard engine, 127 CID-85 mm bore (Oil filler pipe above starter)
Ferguson 30 :
TO-30 : Continental Z129 engine, 129 CID (Oil filler pipe near front of engine close to fan)
Power :
TEA 20-80 : approximately 24 HP at PTO
TE/TO-20 : approximately 25 HP at PTO
TEA 20-85 : approximately 28 HP at PTO
TO-30 : approximately 29 HP at PTO
Serial numbers (on a plate attached with rivets behind the steering wheel, above the throttle) :
TE-20 (England) :
1946 : (1-315); 1947 : (316-20894); 1948 : (20895-77772); 1949 : (77773-116461); 1950 : (116462-167836); 1951 : (167837-241335); 1952 : (241336-310779); 1953 : (310780-367998); 1954 : (367999-428092); 1955 : (428093-488578); 1956 : (488579-517651).
TO-20 (USA) :
1948 : (1-1807); 1949 : (1808-14659); 1950 : (14660-39162); 1951 : (39163-60000).
TO-30 (USA) :
1951 : (60001-72679); 1952 : (72680-108644); 1953 : (108645-125928); 1954 : (125929-140000).
Notes on modifications :
TEA20-80 (80 mm bore) : used up to serial # 172598; water pump is mounted on engine block.
TEA2-85 (85 mm bore: used after serial # 172598); water pump is mounted on head.
Serial # 200001 : electrical system switch from 6 to 12 volts and air intake is via a screen on dashboard.
Rlach
Nebraska Cowman
02-13-2005 02:48:33
if you could post some pictures that would be a big help. Most Fergies I'm famillier with had a tag by the steering wheel. does it have hi-lo range? if it is just a straight 4 speed it's likey a TO20 or 30 the TO30 can be spotted by the aircleaner intake in the dash, a round screen with a domed lid protecting the top half.
bryan86
02-13-2005 06:53:34
 Re: ferguson tractor in reply to Nebraska Cowman, 02-13-2005 02:48:33
I guess it would not be a straight 4 speed. it has i believe to be a fifth gear. the tag behind the steering wheel you can not read the number on it.
Chuck (CA)
02-13-2005 07:02:28
 Re: ferguson tractor in reply to bryan86, 02-13-2005 06:53:34
What you believe is a fifth gear is most likely the "Start" selector. If original, you would put the shifter there in order to fire it up. Mine was bypassed before I got it and now works with a key.
On the side of the block you should see either Z129 stamped (TO30) or Z120 (TO20).
Maybe if you wet the plate by the steering wheel, you could make out the serial #. Also, if you go to the Ferguson board, there's a lot of very knowledgable folks there.
Chuck
bryan86
02-13-2005 10:13:46
 Re: ferguson tractor in reply to Chuck (CA), 02-13-2005 07:02:28
Yes that i guess is the start. it has 1, 2, 3, 4, S, R. I did get the number from the bottom of the plate and it is TE 30692
Nebraska Cowman
02-13-2005 10:59:19
 Re: ferguson tractor in reply to bryan86, 02-13-2005 10:13:46
bryan, that would be a TE-20 built in 1948 in Great Britan
bryan86
02-13-2005 15:54:35
 Re: ferguson tractor in reply to Nebraska Cowman, 02-13-2005 10:59:19
thanks so much for your help
Nebraska Cowman
02-13-2005 07:01:27
is your "5th" gear in the upper right hand corner?
