Tractor Talk Discussion Forum
1969 434 International Harvester,,,just bought!
GW
02-10-2005 08:12:10
Hi.I had posted a few messages on this tractor,about what exactly it was.Well i seen the tractor,,and it is a 1969 434 International Harvester.It had new injectors,new glow plugs.Motor is good,starts good and runs smooth.This has a very good front end loader as well.This ia a 4 cylinder diesle..... .We have just purchaced it,and it is being delivered on Saturday....Question,,are these tractors,realiable?...This is our first International.Ill post a pic later.....GW
Quebec Red
02-10-2005 15:19:05
 Re: 1969 434 International Harvester,,,just bought in reply to GW, 02-10-2005 08:12:10
These tractors are the older model of the 444 and 354. The BD154 would have a lifespan of 3500 to 5000 hours. We had one with a 1501 IHC loader. The diesel is very cold blooded and required a 1500 watt tank heater to assist starting in cool or cold weather. The glow plug system must be properly maintained. When the 434 was 3 years old we replaced it with a 454 and an 1850 loader. this had the Nuess 179 inch direct injection motor. Never use ether in the 434 It is a good light duty tractor. Good luck. QR
GW
02-10-2005 19:00:05
 Re: 1969 434 International Harvester,,,just bought in reply to Quebec Red, 02-10-2005 15:19:05
Thanks for the advice.We intend to only use this tractor,for plowing snow,,gardening,bush hog use,and light wood hauling.This is the first International we owned..... we had a Ford 3000,(still got it)..wont start at all,in "cool" weather..... .GW
Hound
02-10-2005 12:14:25
To make it reliable....get rid of that Lucas, princess of darkness generator and replace it with an alternator. That will keep your battery up and charged and she'll start on the coldest of days. Hound
Peters
03-02-2005 10:11:08
 Re: 1969 434 International Harvester,,,just bought in reply to Hound, 02-10-2005 12:14:25
I"ve got a 1962 B414 and the engine was shot at 5,500 hours. Fit the alternator. These engines don"t like condensation inside (the cylinder head / valve seats corrode) Avoid loads of short runs, fit a new thermostat, change the oil frequently. They are good tractors if a little light. Does anybody know what the hydraulic pressure is?
GW
02-10-2005 15:00:19
Hi...Yes,i think it has an alternater on it now.I believe that i seen one installed,it isnt a generator,im sure of it.Anyway,,ill know Saturday,when we get the tractor,,and if its a generator,ill see that it is replaced.Thanks ,for all your info on this tractor.As i said,this was our first international..and wanted to see if the 4 cyl deisles,would start,and hold up,and what these tractors would be like..... GW
txblu
02-11-2005 04:10:47
 Re: 1969 434 International Harvester,,,just bought in reply to GW, 02-10-2005 15:00:19
But I wouldn't fix it if it ain't broke. Wait till it fails.
While in here, I had a '74 464 gas for several years. Only problem was a cracked exhaust manifold and hard starting. Hard starting was probably my fault as it was early in my tractor days and I was learning how to keep em running.
Part of my problem was not shutting off my fuel when finished but you won't have that problem with your diesel. Also since your combustion temp is lower than with gas, you probably won't have the cracked manifold problem either.
Good luck.
Mark
