Tractor Talk Discussion Forum
Mitsubishi Tractor
Dennis038
02-09-2005 03:01:43
Hi. I own a Mitsubishi 2501D. I have had the radiator tested and it is quite fine and capable, but I cannot seem to get a radiator cap to work correctly on this tractor. It blows all of the coolant out thru the overflow hose. I have replaced the cap with a new one marked 13 LBS just like the one that came on it. I am beginning to wonder if this is the correct setting. Does anyone know for sure, what pressure the radiator cap is supposed to be? Thanks for your response. Dennis
mpsouls
10-16-2006 12:12:02
 Re: Mitsubishi Tractor in reply to Dennis038, 02-09-2005 03:01:43
Dennis if you still have your Mitsubishi tractor shot me a letter I would like to talk to you. Curtis
Dave1
02-09-2005 05:58:08
Mike's right , check for air bubbles in radiator , these tractors are noted for bad head gaskets. Its not a bad job to do, just make sure to have the head resurfaced. Dave1
Mike M
02-09-2005 04:57:45
Run it with the cap off and check for bubbles,it sounds like you have a blown head gasket.Napa sells a sniffer tester for around $50.00 that can detect even a small leak.
