Tractor Talk Discussion Forum
John deere Model LA
Jim mc
02-08-2005 19:01:44
I need information on the LA model. What is the shift pattern? Does the number on the side of the shifter housing have any thing to do with the serial number?
Gene Davis (GA)
02-08-2005 19:10:37
 Re: John deere Model LA in reply to Jim mc , 02-08-2005 19:01:44
The shift pattern will be the standard "H" pattern with reverse in the upper left corner, low in the lower left corner, second in the upper right, and high gear in the lower right corner. The numbers are casting(mfgr)numbers. Gene Davis
AZ Jack
02-09-2005 18:41:01
 Re: John deere Model LA in reply to Gene Davis (GA), 02-08-2005 19:10:37
Your serial number should be on a tag on the back of the right rear axle housing-sometimes these get knocked off. Jack
