Tractor Talk Discussion Forum
CASE 1370
TRACTOR JOCKEY
02-03-2005 10:59:23
OUR CASE 1370 HAS A COUPLE OF PROBLEMS THAT I WAS WONDERING IF ANYONE NEW ANYTHING ABOUT. THE BRAKES FEEL AS IF THEY ARE SLIGHTLY ON MOST ALL OF THE TIME, ESPICALLY WHEN COLD. WE HAVE HAD THE MASTER CYLINER GONE THROUGH BY THE DEALER , NO LUCK. ALSO IT SMOKES BLACK SMOKE OUT OF EXHAUST UNDER ANY LOAD. ITS BEEN OVERHAULED,NEW INJECTORS AND PUMP. STILL NO LUCK, I KNOW ITS SUPPOSE TO A LITTLE BUT THIS IS EXCESSIVE
brtx
02-04-2005 06:03:31
 Re: CASE 1370 in reply to TRACTOR JOCKEY, 02-03-2005 10:59:23
jockey check your air filter.its not gettig enough air to burn all the fuel during combustion.too much air would give you a white smoke.how many hours since rebuild?are you getting excessive blow by? dont have a clue on the brakes.
Can't even use my name
02-03-2005 15:18:46
As far as the black smoke you may want to check the air filter and check the turbo boost. It may be turned way up too! Not sure on the brakes as they are internal.
