Tractor Talk Discussion Forum
CUB HYDRAULIC UNIT
JIMLLL
02-03-2005 08:38:42
The hydraulic system loads the engine excessively when lowering the mower. Does anyone have suggestions with this problem? I would like to purchase a repair kit for the hydraulic system. Does anyone have a source other than IH?
THANKS
Kevin (FL)
02-03-2005 12:08:42
 Re: CUB HYDRAULIC UNIT in reply to JIMLLL, 02-03-2005 08:38:42
Ours will just about kill the engine when its cold. Make sure you have the correct fluid (HYTRAN) and that it's full (a little over 2 quarts) and then cycle the system up and down to bleed any air. Also, grease the zerk fittings on the lift shaft bushings and make sure all other linkages are freed up and lubed.
Gravy
02-03-2005 11:03:57
I think all the Cubs groan when lowering the load. My snow blade does the same. I think that's normal...
