Tractor Talk Discussion Forum
NEED INFO ON FARMAL F14
LANEY
02-02-2005 09:37:23
I HAVE A 1936 OR 1937 FARMAL F14 W/ ORIGINAL OWNERS MANUAL LEFT TO ME FROM MY DESEASED HUSBAND. TRIED TO PULL IT TO GET STARTED IT TURNS OVER BUT WON'T START. ITS IN GREAT SHAPE. WOULD LIKE TO SELL SOON. COULD SOMEONE PLEASE HELP ME W/ SOME INFO? HOPE TO HEAR FROM SOMEONE SOON, THANKS, LANEY IN MISSOURI.
Sloroll
02-02-2005 13:17:53
 Re: NEED INFO ON FARMAL F14 in reply to LANEY, 02-02-2005 09:37:23
Are you sure it isn't an F-12? F-14 look very similar but were built 1938 and 1939. A F14 is usually worth a little bit more than the average F12. The serial number should be under the fuel tank on the front tank mount. It will be a tin tag. That will help identify your tractor and propper year. Make sure good gas is getting to the carb and that there is spark from the mag. If pulling make sure the spark lever on the mag is full down too. If cranking by hand pull the spark lever up one third.
old
02-02-2005 11:32:32
What type of info do you need. I'm also in Missouri by the way.
Missouri Boy
02-03-2005 03:35:12
 Re: NEED INFO ON FARMAL F14 in reply to old, 02-02-2005 11:32:32
Old, Are you the one at Lake of the Ozarks? I was talking to a fellow from Farmington who just bought a JD 40 at Eldon, Mo. Did you ever hear of Cape Girardeau?
old
02-03-2005 09:26:12
 Re: NEED INFO ON FARMAL F14 in reply to Missouri Boy, 02-03-2005 03:35:12
Yep I'm at the lake, yes I know where the cape is.
