Tractor Talk Discussion Forum
Correction.. TRANSAXLE
Dave in MAnches
01-29-2005 09:57:49
It is the transaxle. Where do I find the filler tube or plug..again thanks
Bob
01-29-2005 16:20:55
 Curious in reply to Dave in MAnchester, 01-29-2005 09:57:49
Just curious... where's the original post this is in reference to?
Bob
01-29-2005 18:30:38
 Re: Curious in reply to Bob, 01-29-2005 16:20:55
OK, got it. I must have looked at this page 20 times, and skimmed over the original post!
RusselAZ
01-29-2005 15:09:00
 Re: Correction.. TRANSAXLE in reply to Dave in MAnchester, 01-29-2005 09:57:49
The sears 12 transaxle will have a drain plug on the RH lower side of the case, RH looking at it from the rear. The filler pipe is an elbow just above the left axle support. Filling is easier by taking out the shifter, 4-1/4 inch bolts. They hold 3 quarts of 30 wt motor oil if you live in cold country.
Russ Smart
01-29-2005 13:42:15
One that we had I drilled a small hole in and then pumped some gear oil in, because I thought it might need some aditional lubrication. drilled and tapped 8-32 so I could plug the hole. Before long it started to drip a little from around the axle shafts, so I guess I should have left it alone,although it didn't drip much. I undestand if the're not hydrostatic most are just packed with grease for life.
sammy the RED
01-29-2005 11:12:25
Some of the transaxle mowers do not have a filler plug. They are sealed.
Did you buy it at N Livestock ?
TomTX
01-29-2005 11:06:11
Need at least a few hints what you are talking about? brand, model, etc.
