Tractor Talk Discussion Forum
JD R pony motor...your thoughts
old fashioned f
01-26-2005 09:04:52
third party image
Howdy folks,
Well, a problem I've been living with for about a year or more has finally gotten to the "uh oh, now I have to do something about this" point. I've been having issues with my pony motor clutch not wanting to engage the cogs on the flywheel so I can crank the big motor over. It just wants to grind against the flywheel and not slide into position to start cranking. For a good while all you had to do was pull the pony clutch lever a few times and it would eventually seat itself in but now it won't at all. I started workin on removing the clutch housing down in the barn yesterday (unfortunately it didn't quit in the shop) and found I'll have to either remove the pony motor from the tractor or pull the flywheel in order to get it off. So, to make a long story short, has this happened to anyone here and if so what caused it? Like I said, I haven't gotten into yet but wanted some ideas of what to look for when I find a way to get it pulled up to the shop and started so i can drive it in (it's in the barn in front of all the tractors that could pull start it and all I have otherwise is my farmall A ha ha). God bless.
--old fashioned farmer
p.s. the pic is of the R when I had it split in the shop workin on replacing 3 gears and the transmission gasket back in the summer of '03. Fun time that was.
rookie
01-29-2005 05:33:30
 Re: JD R pony motor...your thoughts in reply to old fashioned farmer, 01-26-2005 09:04:52
probably your best bet is to give me that R and get yourself a different tractor
RAB
01-26-2005 14:12:58
Nice Picture!
Now we know why your handle is "Old Fashioned Farmer" - no "lectic at your place!!(or is it my "puter has too much black and not enuff white?)
Hope you get it sorted.
Regards, RAB
buickanddeere
01-26-2005 11:09:25
The engagement problem occurs as the brake and clutch plates wear and require adjustment.Old dry lubricant doesn't help either. The adjustment proceedures are all there in the service manual.
