Tractor Talk Discussion Forum
oliver 77 intake and carburetor
monte sheets
01-25-2005 21:05:42
would like to know if the intake and carburetor of a later series oliver will fit that is bigger for more fuel and air?
770
01-26-2005 18:11:05
 Re: oliver 77 intake and carburetor in reply to monte sheets, 01-25-2005 21:05:42
Yes it will. On one of my 77"s I put the intake from a 770 on along with the TSX 755 carb. A TSX 374 from a super will also fit. The 77 should have on the TSX 363. I"ve had good results with the 770 set up. On that tractor though, I had the head ported and polished..(a puller). Just remember, the ports on the 77 head are smaller than the super or 770 head. As info, the 1550 carb will also bolt up, a TSX 903....But they are harder to find. Don"t over fuel your tractor, I"d recommend if going to a larger carb, a larger intake is a must. Will probably be good for a few more horse. Good luck...Just my opinion....
oliver power
01-26-2005 04:37:51
Yes. the super 77 , and the 770 will fit on a 77. The 1550 may even fit , but don"t know for sure.
old
01-25-2005 21:30:26
Check with the Oliver forum I think one from a 770 will but I'm not sure
