Tractor Talk Discussion Forum
flat drive belt
Don E. Foster
01-24-2005 19:01:29
Where can I find a flat drive belt about 3 to 6" wide and maybe 10' between pulleys? I just am not man enough anymore to start my '29 JD/D by hand. I could use one of my other tractors to start that old thing!!! Thanks
Averyman
01-25-2005 11:16:41
 Re: flat drive belt in reply to Don E. Foster, 01-24-2005 19:01:29
I would recommend a mininum of 30 feet by 6 inches wide. 7 or 8 inches wide would be even better. You need the length because you will need to put a twist in it to get your engine rotating in the right direction. A short narrow belt will just slip off the pulley when you engage the clutch. Maybe someone has one sitting around off an old grain grinder, that's what I use ..
Rod (NH)
01-24-2005 20:10:03
Hi Don,
Try here.
third party image Rod
mattd
01-24-2005 19:38:12
like mike said, you could go to your deere dealer and see if they have a belt that would work. you just may have to flip it inside out. on our combine there is a couple belts that are close to that long but theyre only 2 inches wide.
matt
Gene or Georgia Ann Davis
01-24-2005 19:37:11
Check with a mill supply house or some one like the Grainger company or the McMaster Carr co. Gene Davis
Mike Burdick
01-24-2005 19:33:21
Don,
If you can't get the "real deal" maybe you could use belting from a round baler. Most implement dealers will have this in stock together with the flex connectors.
Mike Burdick
01-24-2005 19:31:18
Don,
If you can"t get the "real deal" maybe you could use belting from a round baler. Most implement dealers will have this is stock together with the flex connectors.
