Tractor Talk Discussion Forum
Felix Snowplow Help
Brad S
01-24-2005 15:33:34
Felix or anyone else,I want to mount a snowplow on the front of my John Deere 2510, I was wondering if anyone had pictures of the plow setup on a 2510,3020 etc.. please e mail Thanks Brad
felix
01-24-2005 19:29:05
 Re: Felix Snowplow Help in reply to Brad S, 01-24-2005 15:33:34
brad mine is made using mostly scrap metal hanging around and part of the original frame. but it looks nice and is real strong. i have a picture taken a couple years ago showing the front of it with my dad plowing. if you want e-mail me with your address so i can send the pic i don't know how to put pictures on this site. i'm not good with metal types but we used 2 pieces of metal if you look at the front they look like [ a c- shaped metal bolted them along the frame rails on the side of the tractor. took the original plow frame ours was from a 72 scout my dad sold along time ago and welded it on top. for a piston we use the one we used for implements i run the 2 hoses (14 ft long) to the back and use the hydraulic remotes to lift. than off the frame in the front we ran 2 thick pieces of angle iron down to where we made the holes for the plow to mount made a bracket behind that so we could bolt another piece of metal at an angle under the axle and up to the frame near the engine area where we made it bolt on. that way you can remove the bolted piece and unbolt the frame and slide the whole thing off the tractor. it hard to describe the pic will do it justice but it looks nice and does the job. only cost i had was the hoses some bolts and a couple welding rods
