Tractor Talk Discussion Forum
Brake squeal...........
jmh
01-22-2005 18:36:58
Have a brake that squeals when applied. The other side makes no noise when used. New brake bands were installed on both sides during rebuild. Brake drums were cleaned with de-greaser.
These are on a B Farmall. Can anyone give me some way to solve this problem.
Thanks..... ..
Fred OH
01-24-2005 09:30:01
 Re: Brake squeal........... in reply to jmh, 01-22-2005 18:36:58
I cured it on an H when I was about ten years old with an oilcan and bout got my bu++ kicked. Fred OH
RAB
01-23-2005 02:12:47
Don"t know really, but as you probably know the squeal is caused by the brake vibrating at high frequency. May be oval drum, lack of lubrication (on the appropriate parts), poor retaining springs, that brake only just being applied, or only one shoe working properly, etc.
You might try putting a slight chamfer on the leading edges of the linings, and also checking the shoes are not running on a high ridge on the drum leaving part of the shoe not contacting properly
Hope this helps, RAB
