Tractor Talk Discussion Forum
49 JD A
terry billings
01-22-2005 18:13:06
I HAVE A 1949 JD A IT HAS A PROBLEM WITH THE
HYDRALIC LIFT ARMS. WHEM I RAISE THEM THEY LEAK BACK DOWN. WOULD ANY BODY HAVE ANY IDEA WHAT THE PROBLEM MIGHT BE?
Maark
01-22-2005 18:22:48
 Re: 49 JD A in reply to terry billings, 01-22-2005 18:13:06
either the gasket behind the powertrol box is bad or the seal on the lift piston is bad. To replace that gasket, just drain the oil and remove the bolts that hold the powertrol box on. If the piston seal is bad you will need to drain the gear lube and remove the complete assembly.
