Tractor Talk Discussion Forum
over spray on rims
Rob in Mo
01-21-2005 22:41:26
This has probably been covered many times but I missed it. I don't know if it gripes you as much as it does me,when I see someone trying to sell a tractor it appears to me that they take a spray can and try to paint the rims, getting more paint on the tires than the rim. It looks terrible and personally turns me away from buying that tractor. Why not take a little extra time and do it right
or leave it the way it was. Any Comments?
Simple Solution
01-22-2005 13:25:42
 Re: over spray on rims in reply to Rob in Mo, 01-21-2005 22:41:26
There is a simple solution to your problem and that is to not buy it, actually you stated that yourself. As for someone else's tractor having some overspray, I too wonder about why but I don't really care one way or the other, after all, maybe he likes them with overspray and he might even lose sleep over someone like me or you who masks off the tires before painting. Someone else mentioned life being too short to worry about stuff like this.
thurlow
01-22-2005 19:13:11
 Re: over spray on rims in reply to Simple Solution, 01-22-2005 13:25:42
Right you are, Simple..... .....can you say "ana1 retentive"????? ?
Simple Solution
01-23-2005 06:02:40
 Re: over spray on rims in reply to thurlow, 01-22-2005 19:13:11
Hey Thurlow, I actually found out the base meaning of "anal retentive". I knew of course that it referred to a guy who had to have all his ducks in a row and super-organized and clean, etc. But a workplace partner explained the actual origins of the term. If you want I will try to explain it here to you, just let me know (or maybe you already do). Sort of interesting, well maybe not interesting but it's at least an explanation.
Redmud
01-22-2005 09:53:16
Guys, life is to short to worry about a little paint on a tire. I ran a rear tire on my tractor that someone had painted white for his wife to plant flowers in, there wasn"t anything wrong with the tire, and it had 80% of it"s life left so I ran it for three years. When I put on new tires, I gave the white one to a neighbor, it"s on his tractor now, you can still see white paint on it, so I don"t reckon it bothers him anymore than it did me.
thejdman01
01-22-2005 09:04:24
those people that dont take any pride in thier work or any time on thier work are the same people who usually constitue changining the oil as "major engine work recently(i changed the oil 5 years ago) done" to them it is major engine work
Van in AR
01-22-2005 08:49:26
All comes down to attention to detail, probably gave the mechanicals the same care, I would pass.
Van
Tim...Ok
01-22-2005 08:19:22
Another thing that works good,is rub vasoline on the tire before you paint..after paint is dry,wipe or wash off the jelly and the paint..easy
Tim
Ed Schulte
01-22-2005 07:53:36
Hello, I have painted a lot of tractors, I found a little paint thinner on a cloth the next day after painting wheels will wipe right off of rubber tire ,works good for me and leaves no trace of paint on the tires. All it takes is a little arm work.
msb
01-22-2005 08:47:24
 Re: over spray on rims in reply to Ed Schulte, 01-22-2005 07:53:36
Like Ed,I too, have painted many tractors and I use the same method except I use a thinner soaked rag immediately after painting the wheels.Never use the rag above the wheel where thinner can run down on the fresh paint.Always from the side or bottom.Get it while the paint is still wet.It comes off real easy then.
BobMo
01-22-2005 06:08:01
At the expense of possibly upsetting someone when I see overspray all over the tires and people advertise it as refurbished or restored I just accept it as an indicator of the type of job that was done. Since its such a minor thing I wonder how much else was done in the same fashion. Then again there are those that just don't recognize a good job. It's my opinion that they probably don't complete their paperwork after their morning constitutional either....
thurlow
01-22-2005 06:19:11
 Re: over spray on rims in reply to BobMo, 01-22-2005 06:08:01
You wipe me out..... ..wiping not related to..... .you know; I assume the paperwork is related to record keeping of the event? A little confused here..... ...
txblu
01-22-2005 06:14:53
My problem has been more of when to paint. When restoring I usually include new rubber. If the paint on the rims is green when the tires are replaced, the tire looks nice, but the paint takes a whacking. Then you have all the touch up which looks just like just that; be it spray or brush.
On units not requiring new rubber (few) I make a mask to keep it off.
Then I have read where some paint black over the rim color to hide it. Guess it works.
My 2c.
Mark
Nebraska Cowman
01-22-2005 05:25:34
I have painted a lot of tractors and never mask tires. I find that what little overspray gets on them quickly fades.
icky
01-22-2005 06:15:23
 Re: over spray on rims in reply to Nebraska Cowman, 01-22-2005 05:25:34
Nebr.Cowman,,,,,so,,,,, you don't finish your "paperwork" after you morning duty either. Nice comment there BobMO,,,,, darned truth probably.
dr.sportster
01-22-2005 05:59:42
Well you just lost Rob as a potential customer.Newspaper is cheap.
RAB
01-22-2005 00:16:34
Its an easy indicator of the way the vendor is marketing his wares. Use it as such, and take advantage if this information if you consider making a bid.
Regards, RAB
