Tractor Talk Discussion Forum
hyd.valve
homerlong
01-18-2005 10:15:12
Anyone have any information for Gresen daul spool hyd.control valve model 2702 its on Allied 450 loader and I think may be a spring or something missing from load port on front left corner of housing on inlet side and also why would the relief valve back left corner of housing need to be turned almost all the way in about 1/4 turn from being bottomed out to move loader up and down. Thanks in Advance !
J. Schwiebert
01-18-2005 14:09:50
 Re: hyd.valve in reply to homerlong, 01-18-2005 10:15:12
You have a gresen SS. The number (2702) is a casting number. That number can be configured many ways when it is BUILT, Get in contact with me before the end of the week and I will try to help you.
homerlong
01-19-2005 04:02:51
 Re: hyd.valve in reply to J. Schwiebert, 01-18-2005 14:09:50
Can you provide parts list or sketch of valve with internal parts.My main concern is if missing something from front port inlet side and if this valve has a float position Thanks
J. Schwiebert
01-19-2005 04:45:46
 Re: hyd.valve in reply to homerlong, 01-19-2005 04:02:51
I can not scan you one, but provide me a U. S. Mail address and I will mail you one. If the casting for the first spool is longer than the second one it has float. Float spools are four position spools so the casting has to be longer to accomodate the longer spool. If you have 2 ports on the outlet side it can be set up for power beyond. If I remember correctly there were also 2 relief valve options and also 2 different springs for these relief valve settings. What is the setting of the relief on your tractor? There needs to be a 250 pound difference or it will not work.
homerlong
01-19-2005 05:23:06
 Re: hyd.valve in reply to J. Schwiebert, 01-19-2005 04:45:46
10183 Bane Rd NE Kensington,Ohio 44427
J. Schwiebert
01-19-2005 07:09:32
 Re: hyd.valve in reply to homerlong, 01-19-2005 05:23:06
Thanks: I am in the northwest part of the state.
J. Schwiebert
01-18-2005 14:10:41
Sorry. That should be a SP valve not ss.
