Tractor Talk Discussion Forum
Haymasters
steveormary
01-13-2005 23:04:27
Question for all you hay masters and Allan. How long do you leave your hay in the windrow before you bale it.
When we put our hay(alfalfa) in stacks we would mow in the morning and start raking the next afternoon and then stack it the same afternoon.
Baler mons wanted to leave it in windrows for several days and then have it turned just ahead of the baler by an hour or two. I was always afraid it would get rained on and didnt like to leave it over 2 days. Cut hay with swather.
steveormary
Mo Hay Baler
01-14-2005 13:05:28
 Re: Haymasters in reply to steveormary, 01-13-2005 23:04:27
I dont see a lot of haystacks in Mo.I usually will start raking when alfalfa has turned a blueish tint,and rattles when you drive on it.You still might have to wait a couple of hours to start baling if the ground is a little soggy underneath.In ideal conditions with warm sunshine and low humidity,I will mow early while the dew is still on,night-time if I have to,and have it baled that evening.
Allan in NE
01-14-2005 05:49:10
Hi Steve,
Hey! I see it is warming up! 6:15 and it's 1 above here this morning already!
Let's see. That's one of those "I gotta feel it" questions and is kind of a regional one, to boot. :>)
But generally, same as you, rake it when the the wilt is on the leaf. Then, wheather raked or swathed, put the hay up when the leafs will fall off the stem if ya even look at it wrong (bone dry). :>)
That was one advantage of stacking hay; you could work it in the heat of the day and not loose any leaves. Baling doesn't work that way; in this dry country, have to wait for the dew to come down at 2am.
Still drives me nuts to see someone running a round baler in the heat of the day. Those leaves are just pouring out the back of the machine and just end up on the ground.
Being raised on a dairy farm, I'm of the opinion that anything other than straight alfalfa is pure junk. If the field is upwards of 3 years old and getting a little cheat and broam grass in it, we would run a spring tooth harrow across it early in the spring time to kill those grasses.
Have a good one,
Allan
old
01-14-2005 05:48:48
I always try to leave it in a row till, when you go out and pick some up with your hand it sort of rattles. Which at times takes a day or 2. But I also don't rake it till it has been down for at least 1 or 2 days that way if it would get raine on it doesn't hurt it as bad
steveormary
01-14-2005 18:25:59
 Re: Haymasters in reply to old, 01-14-2005 05:48:48
thank you gentlemen,thats what I thought. Now I had a field that had been in alfalfa for I dont remember how many years. I would go over it in the spring with a spiked tooth harrow and sometimes just take three cuttings. It always seemed to produce well.
steveormary
