Tractor Talk Discussion Forum
Light switch decal
Nancy
01-12-2005 06:17:47
What do the letters stand for and where can I find a new one?
RustyFarmall
01-12-2005 07:02:49
 Re: Light switch decal in reply to Nancy, 01-12-2005 06:17:47
We need to know what brand, model of tractor you are talking about?
nancy
01-12-2005 07:05:15
 Re: Light switch decal in reply to RustyFarmall, 01-12-2005 07:02:49
Farmall B (1940) I think
RustyFarmall
01-12-2005 09:13:27
 Re: Light switch decal in reply to nancy, 01-12-2005 07:05:15
The original decal has four letters, L, H, D, and B. L is for low charge, H is high charge, D low beam, B high beam. The original generator was set up with a cut-out relay, rather than an automatic voltage regulator, thus the need for the high and low charge settings in the light switch. Under normal use of the tractor, you would select low charge so as to not overcharge the battery, but if the engine has been started and stopped several times without giving the battery a chance to fully recharge, then you would select high charge, which allows the generator to charge at a higher rate. When you select either D or B for the lights, the generator is simultaneously put in the high charge mode.
John *.?-!.* cub owner
01-12-2005 11:18:28
 Re: Light switch decal in reply to RustyFarmall, 01-12-2005 09:13:27
Actually B meant "less dim". :-)
RustyFarmall
01-12-2005 12:54:50
 Re: Light switch decal in reply to John *.?-!.* cub owner, 01-12-2005 11:18:28
I used to think B meant to Blow on the candle, makes it brighter.
dr.sportster
01-12-2005 07:35:59
There is info on this in the archives somewhere.I beleive it changes the charging rate of the battery but that is only what I read.Sorry I cant recall the title of the achive info.You are referring to the light sw. positions O,D,B,correct?
