Tractor Talk Discussion Forum
how to fill tires with foam?
Foam
01-10-2005 14:31:23
I've see a few big machines that have foam filled tires. How would one go about that? Just pull the schrader core out and fill it with cans of spray foam? Have to pop the bead and fill with expanding??
SuperHank
01-11-2005 12:04:45
 Re: how to fill tires with foam? in reply to Foam, 01-10-2005 14:31:23
I spent more time fixing flats on my 231s while mowing in the rough territory I finally foamed the fronts. Works great and there is no need for the backs. Adds weight to the front which I needed and have been able to get some mowing done rather than spending my time airing up. I bought a spare tire and wheel at the used tractor store just in case. I would not attempt to do the foam myself.
Bill WI
01-11-2005 09:00:37
Anybody do it on a skidsteer? They run slow and would the spraycans work? Thanks
Mike M
01-11-2005 05:28:36
Best to consult with a local tire shop they should be able to help you out.
BobMo
01-10-2005 19:29:52
You can buy foam filled tires for wheelbarrows, wagons, garden trailers in any farm supply store. They aren't expensive.
For your tractor get a professional to do it. There are a number shops that do it. Make sure this is what you want before you do it and it is expensive.
jaybird-oh
01-10-2005 18:16:19
Personally I'd like to know how to foam fill the small tires on wheelbarrows and garden tractor trailers. Those little tires give me fits trying to air them up when the bead breaks loose.
Joe MD
01-11-2005 15:01:12
 Re: how to fill tires with foam? in reply to jaybird-oh, 01-10-2005 18:16:19
I tried to fix a flat wheelbarrow tire with good stuff by drilling 4 holes in the tire.
Doesn't work and it takes forever to get that stuff off your hands.
HY_Moose
01-10-2005 20:32:59
 putting air in those little headache tires. in reply to jaybird-oh, 01-10-2005 18:16:19
Try this, Take a small rope and put a loop in one end. Now wrap it around the tire, follow the middle of the tire all the way around. Put the other end of the rope thru the loop and sinch it up tight so the tire pushes out at the rim all the way around. now air it up some but be carfull you can break the rope. Moose
LK
01-11-2005 07:32:34
 Re: putting air in those little headache tires. in reply to HY_Moose, 01-10-2005 20:32:59
I've done this with a ratchet strap- worked pretty well. But foam in there would be a big help. I generally pump that green "slime" into small tires like that. That seems to help keep them from leaking.
Lincoln
01-10-2005 17:53:05
A friend had the fronts done on his 8N Ford. It worked well for him. The tire shop in town did it for him. He did a lot of bush hogging around locust trees and had constant flats.
old
01-10-2005 17:49:55
Wal-mart/lowes spray foam will not work in tires
JT
01-10-2005 16:37:03
I know I will catch flack about this, but I would not even think about foaming tires, why?
rough ride, will kill back, kidneys, anything on your boby.
the rough ride will also be rough on your tractor, heard can cause the tin, casting, etc to break, the air in the tire act as the shock absorber on a tractor. You also loose the ability of the tire to flex and can cause you to loose traction.
now you have my .02 worth.
leland
01-11-2005 13:20:43
 Re: how to fill tires with foam? in reply to JT, 01-10-2005 16:37:03
I don't know about that JT I once operated a 544 deere loader with foamed tires ride was not the greatest but I survied, but as you posted they suck in mud you sink like a rock fast but no flats that was nice ripping up old rail roads.
Dan B
01-10-2005 16:20:10
Not sure how they do it but I would think twicw about doing it. Sure flat tires are eliminated but time spent going to the back cracker replaces trips to tire shop
FOR WHAT ITS WORTH
buickanddeere
01-10-2005 19:29:20
 Re: how to fill tires with foam? in reply to Dan B, 01-10-2005 16:20:10
Tire foaming is an art and science. For manlifts etc, the harder the foam the better. For a field tractor the foam can be mixed and injected for a tire to feel little different from an airfilled tire.
