Wonder what your opinion of the off-topic & 'fun' stuff is - which pushes your question out of view..... Anyhow, regular arms probably don't fit for one reason or another - wheel clearance, etc. The quick hitch will help. Remember your tractor problably does not have a lot of weight & power, so making the arms longer might lower the capacity of wat you can lift/ use with it. There is a somewhat cheaper thing instead of a quick hitch - two grab claws that bolt on the lower ams. Might be a good solution. They work like a quick hitch, but allow the lower arms to spread or narrow, and use a tipical top link (screwed a bit longer). The net effect is that you can hook up the lower links very easily, but have more work finishing up with the top link hookup & all. However, you retain the flexability and variable dimentions to work with many different imlements that aren't always 'standard' size. There may be others, but one such setup is 'Pats easy Lift' which you can get at www. tractor by . net among other places. Hope this helps - I always thought this place used to be about helping people, rather that a lot of 'fun' & car talk. Few more of those & I wouldn't have even seen your message.... That web site (you need to remove the spaces, it gets censored here) also has a lot of help for compact users, and they keep the riff-raff out so you can get some help to your _tractor_ questions. Guess I don't understand the new breed around here, the more 'fun' they make it, the more worthless this place seems. ;) --->Paul
