Tractor Talk Discussion Forum
Hydraulic Pump need some help
Jerry L /AZ
01-09-2005 16:13:36
I am working on a ford series 800 model 850. front mounted hydraulic pump, it is a gear pump I have 3 pumps two are right hand and one is left hand they are all Prince pumps. the pump that the guy that I bought the tractor from had installed a left hand pump. the crankshaft rotates clock wise. if I remember right on a gear pump the oil enters into the large port and is pushed thru the gears and out the small port. PLease correct me if I am wrong. so if you have left hand pump turning clock wise you will be trying to tack a sucktion on the discharge side. right or wrong??? thanks for your help Jer
J. Schwiebert
01-09-2005 18:58:09
 Re: Hydraulic Pump need some help in reply to Jerry L /AZ , 01-09-2005 16:13:36
Two pop is correct. You always use a left hand pump as a crankshsft driven pump. On the other stuff it depend internally if you have a "drain trap" on each side or just one side of the wear plates. Questions?
Jerry L /AZ
01-09-2005 19:48:00
 Re: Hydraulic Pump need some help in reply to J. Schwiebert, 01-09-2005 18:58:09
Is there a way to change a right hand to a left hand? I guess I bought the wrong pump they are straignt tooth gears can you change it by turning the houseing around? Jer
twopop
01-09-2005 17:42:49
the crankshaft turns clockwise.that would be looking at the enginefrom in front of the radiator.the left hand pump turns counterclockwise.you hook up the pump on the front,with the crankshaft facing the pump shaft.if you sit on the tractor seat,both the engine and the pump are turning ccw
NC Wayne
01-09-2005 16:45:27
Hey Jerry, your right in that the oil should enter through the larger port and exit through the smaller port. Unless I misunderstood what you were saying though, the oil doesn't actually go "through" the gears. Instead it rides around the outside of each gear in the pockets created between the teeth and the pump housing. Regardless of that though, you are right in saying that a pump turning the wrong direction is actually putting the suction on the pressure port and discharging through the suction port. Unless it has some sort of internal valving that would prevent it, the pump will pump this way, the main thing is at high RPM there is the chance that the pump will start cavitating from low oil flow.
Jerry L /AZ
01-09-2005 19:42:26
 Re: Hydraulic Pump need some help in reply to NC Wayne, 01-09-2005 16:45:27
Ok now what you are saying it that I need another left hand pump. I bought the wrong pump right hand is there a way to change it they are the same identical pump except the rotation. they are straight gears would turning the houseing around do it? Jer
NC Wayne
01-09-2005 16:48:40
Forgot something. I'm not sure on the Prince pumps but some pumps have bleed off ports from the pressure side to lube the bearings. If the pump is installed where it turns backwards then there is no pressure to these ports therefore no lube to the bearings...which ain't a good thing..
