Tractor Talk Discussion Forum
Cub crankcase looses prime
Ron Thomas
01-08-2005 12:02:28
Has anyone experienced a farmall cub(58 model)not picking up the oil because of loosing its prime.If so, whats the quick fix; and the long term fix if there is one?
Bus Driver
01-09-2005 12:58:05
 Re: Cub crankcase looses prime in reply to Ron Thomas, 01-08-2005 12:02:28
This can happen from sitting without running for months. There is a pump priming plug in the edge of the engine block flange on the left side at the rear of the block. It is mostly hidden behind the hydraulic lines and requires an Allen wrench. Squirt in engine oil with a pump oiler, replace the plug.
Jerry/MT
01-08-2005 16:57:30
Usually this means that there is a leak in the oil pickup tube or a crack in the tube. Pull the pan and closely examine the pickup tube for cracks and make sure that the seals at the joint(s) are sealing.
