Tractor Talk Discussion Forum
93 wt 1500/4.3 v-6
BIG E
01-07-2005 08:52:00
I have 93 WT1500 chevy pickup with 4.3 v6.Uses no oil.Runs good.But recently has no power.Changed plugs,wires,cap,rotor,fuel filter.Any suggestions on what to try? Has 118k on it.
Remus
01-07-2005 17:09:27
 Re: 93 wt 1500/4.3 v-6 in reply to BIG E, 01-07-2005 08:52:00
My 1995 did the same thing, no power made a whistling noise on a pull. Replaced the cat. converter and muffler. That solved the problem. The converter is expensive.
Larry
thejdman01
01-07-2005 11:23:19
fuel pump? pressure regulators on them sometmies go bad. air filter. theres a sock over the pump in the tank they rarely get plugged but can suck up garbage if you ran the tank low.
marty g.
01-07-2005 11:20:12
The factory cat converter are restrictive to start with, and by the symptoms you describe, I would replace it.
Tim...OK
01-07-2005 09:51:15
I had a 91 WT1500,cat plugged up on me at about 140,000..seriously low on power,then got worse once it plugged up (grin)
Tim
Dick A
01-07-2005 09:33:47
The EGR valve was bad on my Astro Van.
dr.sportster
01-07-2005 09:08:31
Sounds like time for the compression gauge to do alittle check out of the top end.First dry if low squirt oil in cyls. If it goes up ;rings If it stays the same but still low on reading its up top more in the valves.
