Tractor Talk Discussion Forum
Speaking of Gas Tank Filler Necks...
Dug
01-05-2005 17:50:53
Mine, on the JD 2510, spins when I try to screw the lid on. The neck itself has a joint about 6 inches down. Is there anything I can do to "weld" it. I do have an AC/DC buzz box, if I was going that route what rod would you recommend?
Thanks,
Dug
And, yes, I was kidding about the buzz box.
Mike M
01-06-2005 05:42:52
 Re: Speaking of Gas Tank Filler Necks... in reply to Dug, 01-05-2005 17:50:53
I think our 4020 has a hose with clamps on it at that joint from the factory. Pull off the hood and check it out,it may just need tightened.
old
01-05-2005 19:22:49
If you weld it or use a touch be careful and don't blow your self up
Dave Sherburne, NY
01-05-2005 18:33:15
I would recommend a piece of hose and a couple of
clamps
Allan in NE
01-05-2005 17:53:42
Dug,
I think those joints are supposed to be "sweated" together with solder aren't they?
Allan
Dug
01-05-2005 18:36:27
 Re: Speaking of Gas Tank Filler Necks... in reply to Allan in NE, 01-05-2005 17:53:42
Ya know, I think your right, Allan. I believe I will give her a try in the morning.
Dug
