Tractor Talk Discussion Forum
Kubota L245DT
Dan Lago
06-03-2007 06:01:41
I just rebuilt the motor on this tractor, and after firing it up I noticed a small water leak on the front of the motor. I shut it down and found a weap hole next to one of the larger bolt holes on the water pump, I pulled the pump off and there is a passageway that goes in to the timing cover. I asked several different mechanics at our local dealer and knowbody knew what it was for.but all agreed its on all the Kubota water pumps.The only thing that makes sence to me is its an idicator of a bad o-ring on the water outlet tube on the front of the block. Does this make sence to anyone if that o-ring goes, and there was nowhere for that water to go it would blow out the timing cover gasket and head for the oil pan. The books arent that clear and I dont speak japenees.
Walt Davies
06-03-2007 07:46:46
 Re: Kubota L245DT in reply to Dan Lago, 06-03-2007 06:01:41
Sounds like a typical system on most water pumps where they will have a hole to let you know that the system needs repair before you really need to get it fixed.
Walt
Dan Lago
06-03-2007 08:49:30
 Re: Kubota L245DT in reply to Walt Davies, 06-03-2007 07:46:46
Well I thought that at first to, but theres another hole on the neck of the pump for that.
