Tractor Talk Discussion Forum
Another Battery Question:
Dick
01-03-2005 22:53:30
I've always been told not to leave a battery sitting on a concrete floor,,,, it will discharge it.. Also been told that you can't charge a battery while sitting on a concrete floor.. A question for all the experts: Is there any truth to this? If so, why does a battery sitting on a concrete floor discharge it?
Thanks,
Dick
Jon H
01-04-2005 08:19:11
 Re: Another Battery Question: in reply to Dick, 01-03-2005 22:53:30
The only reasonable explanation for why this would happen is that a battery sitting on concrete will lose heat to the cool concrete.A battery that is cooler than the surronding air will "sweat" and cause the battery top to condense moisture from the air,both inside and outside the case. Any but a freshly cleaned battery will have a layer of sulferic acid on the internal and external surface of the battery top.If this layer is dry,it will not conduct power and discharge the cell.If wet with condensation,it will conduct a bit of power across the battery top to the cell connectors and cause a slow discharge. When battery tops were hard rubber with tar to seal the joints,I suspect the wet cover discharge problem was much worse with the porus surface and cracks in the tar sealer to hold acid. I syspect this wet top problem would not exist with a sealed battery like an Optima or an Exide Orbital with no vents to allow damp air in and no acid layer on the outside of the case.
JT
01-04-2005 07:13:05
Cannot explain why, but we have had batteries on concrete floors go dead a lot quicker than if sitting on concrete floors with a rubber floor mat between them. I know every one says it is BS. Must be in differant parts of the country things happen one way and in another it happens another way. I know in Illinois it DOES HAPPEN!! So, as was stated, I keep all my batteries on a rubber mat or shelf and have no problems with discharge.
Rodger
01-04-2005 05:07:48
1- Batteries discharge anywhere, this is a normal chemical process;
2- Old batteries discharge at higher rater than new ones;
3- My father told me that story 50 years ago; since that time I take pleasure to leave half storage batteries on concrete and the other half on a wood bench : the results, no significant differences;
4- Conclusion : if a battery is in good condition, you can leave it on a concrete floor; charge it at low intensity once a month if possible, to avoid sulfate deposits on lead.
Rodger
NEsota
01-04-2005 07:39:02
 Re: Another Battery Question: in reply to Rodger, 01-04-2005 05:07:48
The reason that this "old wives", tale may have some merit is: If the top of the battery is damp some current will flow between the posts. There may be ambient temperature fluctuations that cause condensation to form on the battery. This may happen more when the battery is not temperature insulated from concrete,which acts as a heat sink, keeping it cooler longer (ie. below the wet bulb temperature). So, me thinks that it is the temperature insulation rather than the electrical insulation between the battery and the concrete that is the factor.
Rodger
01-04-2005 05:27:59
 From N-Board in reply to Rodger, 01-04-2005 05:07:48
Paraphrased from N Board :
Barry 01-05-2004 14:13:44
Contacted Interstate battery and got this answer from technical person; Bill Sutton.
Storing Batteries On Concrete Well, here we are within months of the new Millennium, and I�m writing an article about an age old question . . .�Will a battery be damaged or mysteriously discharged by allowing it to sit on a concrete?� At least once a month, someone calls and asks this question or asks for clarification on the subject. Fact or Fiction
Well, is it true? Will a battery be damaged or discharged by letting it sit on concrete? NO!
Why then do so many people believe that concrete is a battery enemy? Years ago, batteries could have been electrically discharged by sitting on a concrete floor. My dad, for instance, owned an automotive shop for many years. In fact, I grew up on a creeper. My dad reminded me time after time, �Sit that battery on wood! I know batteries discharge on the concrete because I�ve witnessed it!� And he was right at that time.
Historical Basis
You see, the myth that concrete drains batteries does have some historical basis. Many, many years ago, wooden battery cases encased a glass jar with the battery inside. Any moisture on the floor could cause the wood to swell and possibly fracture the glass, causing it to leak. Later came the introduction of the hard rubber cases, which were somewhat porous and had a high carbon content. An electrical current could be conducted through this container if the moist concrete floor permitted the current to find an electrical ground. The wise advise of the old days to �not store batteries on concrete� has apparently been passed down to us today, but it no longer applies because of the advanced technology of today�s batteries. Today�s Technology
For more than a decade, automotive and commercial battery containers have been made of polypropylene, which is a highly insulative material. In fact, the Interstate Batteries poly material is at least five times more insulative than the old hard rubber. Also, tremendous technological improvements have been made in the sealing of the battery cover to the container and in the sealing around the posts, which has virtually eliminated electrolyte seepage and migration. Battery Discharging
The fact is, all batteries self- discharge whether they�re sitting on the shelf or on concrete. As the temperature increases, a battery�s self-discharge level also increases. Some lead acid batteries discharge 4% - 8% per month at a temperature of 80�F. The level of self-discharge is also contingent upon the type and percentage of lead plate alloy and the cleanliness of the battery.
If the battery has a surface layer of acid or grime, which is electrically conductive, it self-discharges more rapidly. This surface layer may actually allow you to measure the DC voltage across the battery�s poly case (using a 10 meg-ohm digital voltmeter). For that reason, we recommend that you always keep batteries clean, whether they�re in storage or in a vehicle.
Willy-N Read 01-05-2004 19:37:47
Sitting on concrete can discharge but read why below has to do with tempiture differentials. This is from a Battery Manufacturing Company.
AUTOMOTIVE BATTERIES 14. WHAT ARE SOME OF THE MYTHS ABOUT BATTERIES?
14.1. Storing a battery on a concrete floor will discharge them.
A hundred years ago when battery cases were made of porous materials such as wood, storing batteries on concrete floor would accelerate the discharge. Modern battery cases are made of polypropylene or hard rubber. These cases seal better, so external leakage-causing discharge is no longer a problem, provided the top of the battery is clean. Temperature stratification within large batteries could accelerate the internal "leakage" or self-discharge if the battery is sitting on a cold floor in a warm room or is installed in a submarine.
14.2. Driving a car will fully recharge a battery.
There are a number of factors affecting an alternator's ability to charge a battery. The greatest factors are how much current from the alternator is diverted to the battery to charge it, how long the current is available and the temperature. Generally, idling the engine or short stop-and-go trips during bad weather at night will not recharge the battery. Please see Section 5.
14.3. A battery will not explode.
Recharging a wet lead-acid battery normally produces hydrogen and oxygen gasses. While spark retarding vent caps help prevent battery explosions, they occur when jumping, connecting or disconnecting charger or battery cables, and starting the engine. While not fatal, battery explosions cause thousands of eye and burn injuries each year.
When battery explosions occur when starting an engine, here is the usual sequence of events: One or more cells had a high concentration of hydrogen gas (above 4.1%) because the vent cap was clogged or a defective valve did not release the gas. The electrolyte levels fell below the top of the plates due to high under hood temperatures, overcharging, or poor maintenance. A low resistive bridge or "treeing" formed between the top of the plates such that when the current started to flow, it caused an arc or spark in one of the cells. That combination of events ignites the gas blows the battery case cover off and spatters electrolyte all over the engine compartment. The largest number of battery explosions while starting an engine occurs in hot climates.
When an explosion happens, thoroughly rinse the engine compartment with water, and then wash it with a solution of one-pound baking soda to one gallon of warm water to neutralize the residual battery acid. Then thoroughly rewash the engine compartment with water. Periodic preventive maintenance (please see Section 3), working on batteries in well-ventilated areas or using Valve Regulated Lead Acid (AGM or gel cell) type batteries can significantly reduce the possibility of battery explosions.
14.4. A battery will not lose its charge sitting in storage.
Depending on the type of battery and temperature, batteries have a natural self-discharge or internal electrochemical "leakage" at a 1% to 25% rate per month. Thus, over time the battery will become sulfated and fully discharged. Higher temperatures accelerate this process. A battery stored at 95o F (35o C) will self-discharge twice as fast than one stored at 75 o F (23.9o C). (Please see Sections 15 and 16.)
14.5. "Maintenance free" batteries never require maintenance.
In hot climates, the water in the electrolyte is "decomposed" due to the high under hood temperatures. Water can also be lost due to excessive charging voltage or charging currents. Non-sealed batteries are recommended in hot climates so distilled water can be added when this occurs. (Please see Section 3. for other preventive maintenance that should be performed on "maintenance free" batteries.)
14.6. Test the alternator by disconnecting the battery with the engine running.
A battery as like a voltage stabilizer or filter to the pulsating DC produced by the alternator. Disconnecting a battery while the engine is running can destroy the sensitive electronic components connected to the entire electrical system such as the emission computer, audio system, cell phone, alarm system, etc., or the charging system itself because the peak voltage can rise to 40 volts or more. In the 1970s, removing a battery terminal was an accepted practice to test charging systems of that era. That is not the case today. Just say NO if anyone suggests this.
14.7. Pulse chargers, aspirins or additives will revive sulfated batteries.
Using pulse chargers or additives is a very controversial subject. Most battery experts agree that there is no conclusive proof that more expensive pulse chargers work any better than constant voltage chargers to remove sulfation. They also agree that there is no evidence that additives or aspirins provide any long-term benefits.
14.8. On really cold days turn your headlights on to "warm up" the battery up before starting your engine.
While there is no doubt that turning on your headlights will increase the current flow in a car battery, it also consumes valuable capacity that could be used to start the cold engine. Therefore, this is not recommended. For extremely cold temperatures, externally powered battery warmers or blankets and engine block heaters are highly recommended. AGM and Ni-Cad batteries will perform better than other types of batteries in extremely cold temperatures.
14.9. Car batteries last longer in hot climates than in cold ones.
Car batteries last an average of two thirds as long in hot climates as cold ones. Heat kills car batteries, especially sealed wet lead acid batteries. (Please see Section 11.1.)
14.10. Charging Cables or an Auto Jump Starter will start your car.
The cigarette lighter charging cable's advertising states "charges weak batteries in minutes." The charging cable products will certainly recharge your car battery if you have enough time and your battery is in good condition. Cigarette lighters are normally fused at 10 amps, so to be safe they probably limit current flow to 7.5 amps. Given the size of the cord, the amount might be even less.
They work by applying higher voltage from the good battery to "recharge" the bad one. Now let's assume it is a hot day and that you need just of 15% of the battery's capacity to start the engine and that it is a 50 ampere-hour battery. This means you will need 7.5 amps for at least 60 MINUTES to flow from the good battery to the bad one. Now let's also assume that it is a cold day and you have left your lights on. You will need at least 50% capacity or 25 amps to start the car. This will take at least 200+ MINUTES to charge the dead battery. Unless the engine is left running in the car with the good battery, you run the risk of running the good battery down to a point that it might not be able to start a car.
An auto jump starter uses special high current batteries to provide up to 900 peak amps to start your engine. It can provide 200-300 amps for up to 8-10 seconds. After this, the unit has to be recharged for 24 to 48 hours. Standard AA alkaline batteries are used to trickle charge the special batteries. This type of emergency starter should start all but diesel engines up to six or eight times, depending on the condition of the engine and the temperature.
14.11. A larger capacity battery will damage my car.
A starter motor will only draw a fixed amount of current from the battery, based on the resistance of the load. A larger current capacity battery supplies only what is required but will give you more starting capacity and will not damage your car. Using batteries with higher voltage can damage your car. Using batteries that are too large physically can also damage your car.
14.12. Car batteries have memories.
Lead acid batteries do not have the "memory effect" found with first generation Ni-Cad batteries. Deep discharges can damage car batteries and will shorten their lives.
14.13. Bad batteries will not harm the charging system or starter. A bad or weak battery causes more stress on a charging system or starter and can cause premature failures due having to compensate the voltage or current. If you replace a battery, alternator, voltage regulator or starter, you should test the other components for latent or permanent damage.
Ray,IN
01-04-2005 19:14:15
 Re: From N-Board in reply to Rodger, 01-04-2005 05:27:59
Rodger is correct. Here is another source of accurate information answering the discharging question.
MarkB_MI
01-04-2005 03:14:28
The only plausible explanation I've heard for this is that the concrete floor, being colder than the surrounding air, will cause a temperature differential inside the battery that somehow causes it to discharge. Seems to me to be a pretty weak theory.
For what it's worth, an uncle of mine served in the Army Signal Corps in Korea. He said that the Army schools taught them to never place a battery directly on concrete.
novice
01-04-2005 02:57:06
I think it's BS too. How come they don't warn us about it sitting on the base of a metal battery box. Seems like steel is more conductive than cement!--novice
buickanddeere
01-04-2005 05:52:04
 Re: Another Battery Question: in reply to novice, 01-04-2005 02:57:06
A voltage gradiant occurs across the battery plates if the plate is warmer in one spot than another. Voltage output from a battery varies with temperature. So a battery sitting on a cold concrete floor and when the sides/top are warmed by the sun,room heating etc. The battery will discharge a wee bit faster than without a voltage gradiant. The battery won't be dead flat in a month or two however.
george md
01-03-2005 23:40:32
Dick,
Pure unadulterated BS .
george
dr.sportster
01-04-2005 04:46:36
 Re: Another Battery Question: in reply to george md, 01-03-2005 23:40:32
I dont know,under the right conditions all materials including rubber and plastic can conduct electrons.Batteries left on floors have been going dead for years.It may seem like there is no electrical path for current flow but some current must leak through the plastic. casing.Im going to keep mine off the floor.Concrete is a good ground.
