Tractor Talk Discussion Forum
Ford tractor Question
Andy C.
01-02-2005 18:02:12
A friend of mine(Whom is very mechanicaly inclined)was telling me of the problem he has been having removing the brake drums on his Ford 2000 3 cylinder tractor. He says that it appears to come off like an automobile (Lug bolts off,Wheel off, drum off)He has used heat, penetrating oil, sledge hammer, etc. Is there more attachment points on these wheels ? Is he missing something? Any input would be appreciated !
Thank You,
Andy
Roy B
01-03-2005 15:28:39
 Re: Ford tractor Question in reply to Andy C., 01-02-2005 18:02:12
Andy
The mating surface betweem the axle hub and the brake drum is quite large, it takes a lot to break away the years of rust and crud. Make sure the shoes are backed off. There is a groove on the out side of the drum you can hook a big three jaw puller on. Tighten up the puller as much as you dare then apply lots of heat to the drum, just inside the bolt circle. They come free with a very satisifing "thunk".Good luck, Roy
Keith-OR
01-02-2005 22:20:13
Is there an adjustment for the brakes? If so, try backing off that adjustment. Maybe the shoes are worn into grooves in the drum.
HTH....Keith in Gods country
Pitch
01-02-2005 18:43:37
On the N series which is much older there are two large screw on the backing plates that need to be removed. Maybe his has these?
