Tractor Talk Discussion Forum
Allis-Chalmers B
Mike10
12-31-2004 13:57:18
What size can the crankshaft be until I need to put .010 over size mainbearings in.
lucass
12-31-2004 17:19:59
 Re: Allis-Chalmers B in reply to Mike10, 12-31-2004 13:57:18
if your crank is std .you cant put 010 bearings in untill you have the crank reground to .010 .if you have the allis engine you can get .002 under rod bearings though you may use if worn about .002.if you have the b with the hercules engine you will have to have it reground to fit brgs.hercules used a main set with the flange brg on the rear main and a main set with thrust washer on # 4 or #7 main..the nice thing about the brgs set with thrust washers is you can get the washers oversize....lucass
