Tractor Talk Discussion Forum
MF 35 battery connections
angela
12-29-2004 08:29:33
Can you please tell me the correct battery connections for the MF 35 (positive earth or negative earth? (3 cylinder Perkins engine)
Thanks for ur help.
sibby(Aus)
12-29-2004 12:54:38
 Re: MF 35 battery connections in reply to angela, 12-29-2004 08:29:33
Angela, Down under its negative earth for alternator, positive earth for a generator, then again U.S.A. models may differ. cheers for now.
Rod in Smiths Falls, ON,
12-29-2004 13:59:28
 Re: MF 35 battery connections in reply to sibby(Aus), 12-29-2004 12:54:38
What happens with a generator if you get them backwards? Does your voltometer show a backwards reading but the machine starts and runs normally?
RAB
12-29-2004 14:42:11
 Re: MF 35 battery connections in reply to Rod in Smiths Falls, ON, , 12-29-2004 13:59:28
Depends whether the generator is AC or DC.
AC (alternator)- buy and fit a new rectifier and then connect correctly (and possibly a new regulator).
DC (dynamo) - the voltage reg will not work (and will weld contacts together eventually), unless the control box is re-set for other polarity. Yes, ammeter and/or voltmeter will read backwards. In addition generator will not run normally (no charge) unless field circuit is re-polarised by "flashing" the field. Machine may start and appear to run normally, but depends on ignition system, until battery exhausts. For instance, depends on whether it is petrol or diesel. Lots of possibilities to contend with, so need to consider each case on it"s merits.
Regards, RAB
