Tractor Talk Discussion Forum
Hydralics
PatrickK
12-24-2004 08:58:41
What should I put in the Hydralic fluid so it works better in the winter? I"ve drained out as much as possible.
matthies
12-25-2004 05:46:13
 Re: Hydralics in reply to PatrickK, 12-24-2004 08:58:41
I work for the state road dept and we use ISO 32 oil for hydralics flows alot better in cold temps and use this year around.
Jerry/MT
12-24-2004 19:46:26
What does your owners manual say re: hydraulic oil for cold weather operation? You can't go wrong following that.
tony weir
12-24-2004 14:40:19
Depending on temp blend half reg hyd fluid with artic hyd oil sold for use in boom trucks kendel artic blue i use this mix up here in ottawa canada for forklift that run and sleep out side allyear but make sure to change back to right oilin spring as the oilwillbe just like water and you will have lots of small leak when it warms up
550Doug
12-24-2004 14:38:49
 Re: Synthetic for Hydralics? in reply to PatrickK, 12-24-2004 08:58:41
Can a Synthetic oil work in a hydraulic system? How about using a dipstick heater in your hydraulic tank?
old
12-24-2004 10:05:11
Its just like every thing else in the winter you need to let it warm up a little before you use them. Same as you should do with an engine weather it be tractor, truck, or car they sould all be warmed a little before just takeing off with them.
Dean Barker
12-24-2004 09:57:16
John Deere sells a thinner hydraulic fluid; I can't remember what it is called for sure. Lo-Vis I think.
Allan in NE
12-24-2004 09:09:50
Nothin'. Straight hydraulic fluid.
Allan
