Tractor Talk Discussion Forum
GMC/Chevy
tlak
12-22-2004 11:30:15
My tilt steering is loose and Ive heard several times about theighing up the two bolts in the column. How involved is this job?
tompepper
12-22-2004 16:58:58
 Re: GMC/Chevy in reply to tlak, 12-22-2004 11:30:15
I agree,take it to a mechenic..alan.....there are 4 screws in there.but you cant get to the fourth with out tearing more apart.i tightened the 3 i could get at and it worked fine.had a heck of a time with the dimmer switch.got pi**ed and took it to the garage..... god has blessed you if you can do it in 20 mins.
Allan in NE
12-22-2004 17:03:18
 Re: GMC/Chevy in reply to tompepper, 12-22-2004 16:58:58
Hi Tom,
The number of screws thing:
It depends on the year and the model change. The older ones had three, newer models now have four.
Yes, the dimmer, the tilt and the ignition have all got to be "timed" to work together.
Allan
twopop
12-22-2004 16:13:24
if on the steering wheel it says AIR BAG let a gm mechanic do it.
RusselAZ
12-22-2004 14:36:57
There are 4 bolts down inside. Tool needed is a thinwall inverted torx socket. takes about 2 hours . It's worth it to have someone else do it that way you will have someone else for your wife to blame when the dimmer switch doesn't work!!
Harrison
12-22-2004 14:32:06
You'll need a 1/4 drive E7 or E8 female torx socket to tighten the 4 bolts below the tilt knuckle.As for the pivot pins you can get by with a small slide hammer and a machine screw with the right threads.A press plate tool is also needed.The other "floor board full" of tools you'll need are pretty common.It's awfull tricky to get the dimmer switch stuff lined up. Mechanics familar with the job can do it in about an hour,I have seen certified techs take as long as 4 hours and lose all of there religon.A qualified independant garage will usually charge about $45, well worth it to most people.
Allan in NE
12-22-2004 11:59:43
Hi,
Somebody told you wrong; they were thinking of the pivot pins, not the bowl screws, of which there are three.
The job is not too bad, you'll have to get down under the Turn Signal switch. The three little screws hold the upper bowl in place. They take a torex bit.
You'll need the special tool to unload the wheel/ignition lock plate, however. It's about a 20 minute job.
Allan
Allan in NE
12-22-2004 12:22:11
 Re: GMC/Chevy in reply to Allan in NE, 12-22-2004 11:59:43
Heck,
Now that I think about it, I think you have to pull those pivot pins (which also take a special tool) and that the three screws that always get loose are holding down the lower bowl.
Geeeze! Haven't pulled one in 5 or 6 years and my, how the cobwebs filled up my ol' pee-brain! :>)
Allan
Tim...OK
12-22-2004 12:36:06
 Re: GMC/Chevy in reply to Allan in NE, 12-22-2004 12:22:11
Never been that deep in a gm tilt,but had one done,mechanic charged me $80 to tighten'er up..
Tim
Allan in NE
12-22-2004 12:53:31
 Re: GMC/Chevy in reply to Tim...OK, 12-22-2004 12:36:06
Yes,
That sounds about right if a guy has to go all the way to the bottom. Pays something like an hour and a half.
Three little screws and it is those guys that always come loose, seems like.
Allan
buickanddeerre
12-22-2004 13:55:27
 Re: GMC/Chevy in reply to Allan in NE, 12-22-2004 12:53:31
The tilt steering on my GN did the same thing. Had to work under the steering lock, cruise/wiper/high low beam linkages after they were removed. The tilt pins were special. The accessable one pulled easy but the other I finally drove out with a punch instead of pulling it. Tightened the three screws with locktite after shoving the steering together again. Worked for two days than the steering lock linkage came undone. Gave up and had the local GM trained mechanic with the proper tools repair it in less than an hour. Had to go all the way to the bottom again. I wasted 1/2 a day and alot of temper.
Allan in NE
12-22-2004 14:14:57
 Re: GMC/Chevy in reply to buickanddeerre, 12-22-2004 13:55:27
B&D,
Yes, I agree with ya, I guess. If you've never been in to one of these rascals, maybe it is just better to stay outta there.
Lots of pieces, special tools and lots of things that have to be timed correctly again on the way back out.
Allan
