Tractor Talk Discussion Forum
12 volt
dan rausch
12-20-2004 15:48:23
I want to change my old allis from 6 to 12 volts, i know i need a 12 volt coil and alternator, what about my points and condensor. Do I have to change them?
F-Dean
12-21-2004 06:59:20
 Re: 12 volt in reply to dan rausch, 12-20-2004 15:48:23
A Hitachi alternator is small and works well on IH tractors (I put one on my M). You can use your existing coil if you step the voltage down to 6 volts with a resistor before the coil.
Delta Bob
12-20-2004 16:16:15
No , but unless you use a coil with a built in resistor, you will have to add one to the circuit.
If you do not, the points will burn very quickly.
