Tractor Talk Discussion Forum
Oops,broke a stud
Messed up
12-14-2004 14:47:45
Wasn't careful enough.I twisted off a 3/8"stud in the block (flush)of a Continental engine right between 2 cylinders. I hesitate to weld a nut on the stud considering where it is located.Anyone have a better solution.It was coming pretty hard so I think an easy-out is out of the question.TIA, disapointed in myself.
lucass
12-14-2004 19:33:38
 Re: Oops,broke a stud in reply to Messed up, 12-14-2004 14:47:45
have broke a few cont head studs in my day, i drill and tapp them. start with 1/8" bit and work your way up by 1/8's to the tap size.get the first hole centered and youll be ok. lucas
Ol Chief
12-14-2004 20:12:05
 Re: Oops,broke a stud in reply to lucass, 12-14-2004 19:33:38
Try ,putting some anti spatter paste on the block first around the stud.Then place a washer in way of the stud and weld to the stud. Now next weld a nut to the stud and washer.It"s less risky plus the heat may help loosen the stud after every thing is cool.
