Tractor Talk Discussion Forum
What are the good and bad points??
Jrry
12-14-2004 06:03:37
I've seen discussions about particular models of tractors but I would like to know what some of you think are the good and bad points about tractor brands (IH, Case, John Deere, etc) as opposed to particular models. For example I think the Olivers are not fuel effecient as are the David Browns but the Olivers had independent PTO. I'm not asking which brand is best but only what their good and bad points are overall. Which ones are better for loaders, which ones for mowing, etc. thanks for any input.
greenbeanman in Kansas
12-15-2004 06:25:23
 Re: What are the good and bad points?? in reply to Jrry, 12-14-2004 06:03:37
This thread is dipping pretty far down on the page, but I finally have a little time to throw in my two cents worth.
For my "Yesterdays Tractors" mean 1960s and earlier.
I like a slow turning engine with lots of stroke to produce torque, not the faster turning engines that produced it with RPMs. The old Deere and MMs were hard to beat for those qualities.
A lot of the older tractors had small fenders which bathed the operator in dirt all day long. I've always had an oily complexion and can remember coming to the house in the evening with quite a layer of dirt. We ran a GTB MM and an LA Case. The Case had a fuller fender, hence less dirt.
We always believed that the older Case tractors had a propensity for overheating. If we didn't keep the fan belt adjusted frequently and the timing proper we really had to be careful to watch the gauge. The GTB was much more tolerable along those lines.
Our Case and MM were gas tractors. The LA took an extra 5 gallons per half day for doing the same amount of work. An extra 10 gallons per day is quite a bit.
The MM was easier to steer. Perhaps a higher ratio in the steering box?
Right hand clutch vs. left hand clutch. We most often were one-way discing so had a furrow to follow with the right side, hence stood on the right side of the platform. A right hand clutch was more readily available for a quick stop if something should break which wasn't often.
While we never had any engine problems I like the idea of having multiple cylinder blocks, i.e. three blocks with a pair of cylinders in each to make up a six cylinder MM, two-twos for a four cylinder Case, etc.
John Deere "D" tractors had a wonderful napping area for kids to sleep on atop of the transmission housing. Who wouldn't grow to love Ds from those early experiences with dad?
Internationals were a good solid tracor and good workhorses, but we always felt like the horsepower rating was a little more than what they actually had. What does rating matter unless you buy without trying a tractor anyway?
I think that MM was slow to catch up with progress during the row crop era, while fine for the plains wheatland crops. Why spend $800 to $1,000 extra for a 3 point anyway? Could any of us live without it since experiencing it now? My family never owned a tractor with a 3 pt. until I bought a 1070 Case and started growing some row crops. We never owned a loader tractor either, but with 3 strong boys and a strong man in the family what do you need one for? Oh my aching back!
Those are just a few of my thoughts and observations. Deere, Case, MM, & International were the brands we had in our area. Massey Harris/Ferguson, Oliver, and Allis Chalmers were all pretty rare in our area.
johndeereman
12-14-2004 09:28:16
dont get me wrong i bleed green i just love them old tractors the way i see it once you get past the 70's they are all made the same to break down so you will buy more parts if you are a hobby farmer looking for a all purpose tractor thatwill last you should get a dc case or a oliver 88 dieselthe case has a 3pt hitch the only thing wrong with these is no power steering but you cant have everything i wouldnt suggest putting a loader on a jd 4020 too many broken spindles unless you are using it on blacktop id have to say a ford would hold up the best under a loader the jd two cylinders are a good lugging tractor probably the best for pulling horsepower to weight but not good for running a pto equipment i dont know about fuel efficiency just my oppinion brian
Indydirtfarmer
12-14-2004 10:02:17
 Re: What are the good and bad points?? in reply to johndeereman, 12-14-2004 09:28:16
I've got a 1972 4020 that's been in the family since new. It got a loader put on it in 1980. It gets used for everything from loading round bales, to building driveways, to unloading equipment off of trailers. It's never been babied. The front end, including spindles, hasn't been touched since new. It's worn out literally hundreds of front tires, but never a broken spindle. John
Fawteen
12-14-2004 14:24:34
 Re: What are the good and bad points?? in reply to Indydirtfarmer, 12-14-2004 10:02:17
Yup, it's just fantastic how rugged them ol' Deeres are.
Farmall Don
12-14-2004 11:02:43
My wife's uncle has a 4020 with a Wesendorf loader. Now he beats the living daylights out of it clearing tree lines back. In the last 10 or 15 years he has broken a spindle and the bolster frame once. Now my father in law has the same set up since 1983 and has never broken a thing.
my 2 cents
Jonboy
12-14-2004 08:44:04
You would have to be model or series specific to compair brands. In my opinion, every brand had good ones and bad ones and with every tractor I drive I will find things I like and things I don't. Different models have varying features, like you won't find hydrolic brakes, power steering, or live hydrolics and live PTO on a Farmall M, but you will on a IH 484, and tecnology has brought lots of improvments as time marches on. Torque amplifyers didn't come out until around 1954-1955, and were a weak spot if they were abused, but this improvment brought twice the gear selections, instead of the regular 5 speeds ahead on the farmall super M, an super M-TA had 10 speeds ahead and that made finding just the right speed for the job easier. That was the trouble with the older tractors is they didn't have enough gears to choose from for some tasks. It all depends what you are doing as to your tractor needs, old tractors are many times cheaper than a new one, but say if you wanted to run a 3pt tiller or other low speed application, then I'd suggest a newer tractor with a creeper gear for that. Old tractors still have their place, but the newer tractors are able to do some things better and it all depends on your needs and your pocketbook.
kyhayman
12-14-2004 07:13:03
I agree with both Paul and Indy. Local support and and service are critical. Each particular line within a brand has strengths and weaknesses. For example, I love the power to weight ratio of the 1210 and 1410 (and newer versions) of the Case/DB great engines and fuel efficiency, but they leak fluids like a sieve and everything is behind something else. For 5600-7710 series are what I run exclusively now due to low cost and ready supply of aftermarket parts. For me, I never use the dealers shop except for a rare trip to JD. I'd rather keep a spare tractor and then fix it in the winter. Ford fit my needs, they dont have the depth of torque with a turbo 4 cyl that any of the 6 cyls have (IH and JD) for tillage work. Just too many choices to make a blanket statement.
paul
12-14-2004 06:25:43
You would need to break it down to a series within a brand.
For example, the weak link on IHC tractors is the TA tranny - but it is fairly straight foreward & not too spendy to repair one. While it's the weak link, it's also a good feature that I'd want on a tractor I was looking for. Then older H & M models don't have the TA option, so can't fault or praise them....
The Ford had that dreaded SoS tranny, cuts the value of a tractor in half around here when it has that. But the same year, same model Ford tractor with the 5 speed is a really good dependable tractor, but the same year, same model tractor with the 4 speed lacks live pto & does not offer good slow speeds for some applications.
Ollie tractors are generally undervalued for what they are around here, and still a good support network locally, so I would say an Ollie is usually a good buy around here - opposite of what you find.
JD has good parts & good iron, but it is valued so high, it generally is just a collector machine around here, can't afford to use them any more.
Most over-valued machine ever is the Ford N series. Were a great inovation in their day 60+ years ago way ahead of their time, but today are a featureless machine compared to anything from the 50's & 60's, but sell for equal or more $$$$. People just pay money for a cute little tractor without looking at it's value & function.
I find mid 50's to mid 60's IHC & Ollie tractors to be the best bang for the $$$ these days, folks haven't 'discovered' them yet. I'm partial to the Ford 100 series without SoS, probably because the first tractor I learned to drive was a 5 speed..... :)
--->Paul
Indydirtfarmer
12-14-2004 06:22:40
It's impossible to make such a broad generalization of brand vs. brand. You need to factor in what year, what model, and what intended use you are looking at. Every brand has made good and bad models....
One of the prime considerations would be what kind of dealer support you have in your specific area. What may be my #1 choice could be the worst possible one for you.
I tend to favor John Deere equipment made from the late 60's on throught the early 90's. They fit in cost effectively for me, I have a great dealer network locally, and their product was designed for farming the way I do it...
With-in their product line, there are several models that work best for me. They have also made a few that I would have little or no use at all for. Same applies to every brand.
Point being.....I can't see any one brand being "best" for everyone, all the time....John
Jrry
12-14-2004 07:08:27
 Re: What are the good and bad points?? in reply to Indydirtfarmer, 12-14-2004 06:22:40
John, I always appreciate your posts. I'm not really asking about a best brand though just some good and bad points on each brand. Maybe that is too broad a catagory. Does one brand have better axles to support loaders than other brands. Does one have better gear ratios for certain jobs than others. Maybe this does get into specific models also. You mentioned dealer support which I think could go along with the question as a good point for John Deeres.
Indydirtfarmer
12-14-2004 07:17:23
 Re: What are the good and bad points?? in reply to Jrry, 12-14-2004 07:08:27
All I can do is to speak from my prospective. (SLIGHTLY GREEN..!) For a loader tractor, I use a Deere 4020. Kinda over-kill for smaller jobs, but not big enough for others. It has a good heavy front end, that handles loading round bales just fine. I like the Powershift tranny for loader work too. I use a 4440 for most of my planter work. I LOVE the soundguard cab. I have a 4955 MFWD that get's SOME tillage work every now and then, but makes a perfect match for my 850 bu. grain cart. My favorite tractor (can't really explain WHY) is a 2440 Deere. Small (compared to the others) light, nimble, and very fuel efficient (once again, compared to the others). I have a couple old Massey Ferguson's that are good for running augers, hay conveyors, or what-have-you.
These tractors do whatever I NEED of them. They hold up well, and like I said, the dealer I have is PERFECT for my operation.
Don't mess with success..... ...John
RustyFarmall
12-14-2004 06:34:45
Indy, I think you hit the nail square on the head. A good, strong dealer, who will not only listen to your needs and sell you the "right" tractor, but will also back up that sale with parts and service when needed, has more to do with one brand being favored over another than anything else. At one time the green machinery was just about the only color we saw around here, that brand is now being overtaken by a very aggressive and extremely accomodating red dealer.
Indydirtfarmer
12-14-2004 06:51:02
 Re: What are the good and bad points?? in reply to RustyFarmall, 12-14-2004 06:34:45
We have a (Deere) dealer near here that will work with their customers in any way you need. Example...Say a person has a needed repair that they just flat can't afford to pay them to do. They'll walk you through every step of the way, so you can make that repair yourself. They have one mechanic that flat will not work on ANYTHING, unless he has the lattitude to do whatever that tractor needs to leave the shop PERFECT. (He does all my shop work. I've found out that it is cost effective over the long haul) They will bring parts to me all hours of the day or night. And during the fall of 2002, when my wife was in the hospital having surgery, the owner and a couple salesmen came out and baled hay for me one saturday.... I wouldn't even CONSIDER taking my business elsewhere.... Service like that knows no brand or color. John
Allan in NE
12-14-2004 06:45:49
Rusty,
Wouldn't you agree that ol� Indy displayed and uncommonly high degree of self control on his post?
Kinda proud of him. :>)
Allan
Mitchissippi
12-15-2004 15:28:59
 Re: What are the good and bad points?? in reply to Allan in NE, 12-14-2004 06:45:49
He done good didn't he!
Harley
12-14-2004 11:57:23
YEh guys, but there still seems to be a slight bias towards those other color tractors. Once hE said he was just a little partial towards green, but I really think we could get him to come around if we would all go down and help him put next springs crop in or soomething. I think he is weakening, we just gotta WORK ON HIM, lATER, hARLEY
Indydirtfarmer
12-14-2004 13:31:04
 Re: What are the good and bad points?? in reply to Harley, 12-14-2004 11:57:23
YOU'RE RIGHT! In fact, you could convince me even faster should you come down here about hayin' season. Bring your red tractors and your red balers and do all my hay....I'll be more than happy to pat you on the back and say "WELL DONE BOYS"!
(Still keep my GREEN and YELLOW though) John
Harley
12-15-2004 16:59:52
 Re: What are the good and bad points?? in reply to Indydirtfarmer, 12-14-2004 13:31:04
Whatta guy. Makes me all teary. Harley
RustyFarmall
12-14-2004 07:16:06
Yes, it was kind of a touching moment.
Indydirtfarmer
12-14-2004 07:08:42
Flattery will get you everywhere..... ..LOL! John
