Tractor Talk Discussion Forum
Case 530 Tractor problems
Pat Esther
12-14-2004 05:02:30
My husband bought a used Case 530, model G530CB and even a tractor mechanic is stumped on why this tractor is not turning over. Can anyone help us with engine specs such as timing & firing order, etc. The type of transmission fluid and info on brakes. If you know a website that would be helpful for this info we would really appreciate it. Thanks guys!
Jrry
12-14-2004 06:09:10
 Re: Case 530 Tractor problems in reply to Pat Esther, 12-14-2004 05:02:30
Pat, you may want to post over on the Case forum also and put in a bit more information. Sounds like the engine is stuck for what you have posted but you may be referring to a starter problem, etc. If the engine is not turning over you're not going to need the timing order yet.
Pesther
12-14-2004 08:35:10
 Re: Case 530 Tractor problems in reply to Jrry, 12-14-2004 06:09:10
Thanks for answering my question on Case tractors - the bad part is we don"t have e-mail at home so I"m doing this at the school I work at. I do know that Larry replaced the starter & the carbureator. There is spark and compression but the engine won"t turn over. Do you have the address for the Case forum? I would really appreciate help with this.
Jrry
12-14-2004 09:09:09
 Re: Case 530 Tractor problems in reply to Pesther, 12-14-2004 08:35:10
To get to the Case forum go to the same location you posted here but when you click on discussion forum then scroll down to you see Case forum and click there or click here: Link
