Tractor Talk Discussion Forum
1976 Cub Cadet Electric PTO
John J. Wach
12-12-2004 04:57:02
Can someone tell me if an electric pto will engage with the power ON but the motor NOT running? I am getting 12 volts to the pto coil. I am trying to determine if the pto works. Thanks
jim wilkinson
04-27-2005 20:17:49
 Re: 1976 Cub Cadet Electric PTO in reply to John J. Wach, 12-12-2004 04:57:02
I imagine you have your answer by now. Is there a bench test for the various PTO parts? Running a 12 volt positive jumper direct from the battery should tell you if the PTO is engaging. I was able to test mine that way. However, make certain that it will engage again once you remove the 12 volt supply. I think they overheat, and have difficulty energizing again. I'm having PTO troubles myself. I took one off a 782 and will put it on an 1810 tomorrow. The 1810 PTO seemed to be overheating after a few minutes of use.
