Tractor Talk Discussion Forum
40C rear lube
jim barlow
12-10-2004 02:44:01
The rear end, transmission and final drives are filled with black molasses like lube, what is it? Thanks Jim
Mike M
12-10-2004 09:38:31
 Re: 40C rear lube in reply to jim barlow, 12-10-2004 02:44:01
That is JD's SCL type gear lube. SCL stands for sulfur clorine lead. I think the lead is why you can't buy it anymore last I bought was in the 80's
That very well could be the original oil. That stuff is VERY good at protecting from rust as it will creap around and coat everything.I love to buy a tractor with that stuff in it as they usually end up having very good transmissions,I saw this many a time back when I was parting out a few in the 80's and 90's
jim barlow
12-10-2004 12:29:17
 Re: 40C rear lube in reply to Mike M, 12-10-2004 09:38:31
thanks for the oil info, very interesting, what would be the best replacement in you experience. Thanks Jim
