Tractor Talk Discussion Forum
JD4020 on butane - hard to start
WACO GRAND-DAD
12-07-2004 17:36:21
Tractor runs fine after it is started but I have to use starting fluid to get it to crank, even in warm weather. Any help on what might the problem I would appreiate.
txblu
12-08-2004 06:04:03
 Re: JD4020 on butane - hard to start in reply to WACO GRAND-DAD, 12-07-2004 17:36:21
Gonna bet you're on Propane.
Mine wanted full throttle and full choke. Little primer button on the side of the fuel pump/vaporizer. Once the engine is rolling over. hold that button down till it hits.
As soon as it lights off, get the choke off and rpm's down to 1000ish. Let her sit for a couple minutes to get things lubed up and stabilized. The rock the steering trick would help too but you just ran outta hands (one on button, one on key).
I really liked the LP for winter starting as once you had the process down, it was a very reliable starter.
Same starting process in the warmer periods. Just didn't use the liquid prime.
Mark
buickanddeere
12-08-2004 05:10:40
Butane doswn't vapourize as well as propane at low temps.
John A.
12-07-2004 20:55:56
WACO, This is an ol trick I learned on JD LPs a looong time ago. I am sure you cut the Liquid & Vapor valves off after you use it. Even at lunch!
Now.....While cranking the engine, open the vapor,...Now take your free hand, and osolate the steering wheel back and forth about 1/4 turn, rapidly! She should start! I not sure why it works exactly, but I have never seen it not work on those old Deeres. This trick should eliminate the need for ether in all but the dead of winter here in Cen-Texas.
What it does is releave the hydrolic pressure when cranking I think. Hope this helps.
Later,
John A.
txblu
12-08-2004 05:59:12
 Re: JD4020 on butane - hard to start in reply to John A., 12-07-2004 20:55:56
Rocking the wheel takes the pressure off the hyd pump which reduces the load on the engine while attempting to start.
Mark
Gene Davis (GA)
12-07-2004 20:46:44
Sounds like you may need to check the primer button/system which feeds a vapor mixture for cranking before the regular carburetion system begins to feed the engine.
kjm
12-07-2004 19:47:20
W.G.D.,I do not know about butane but we have had L.P. cars and trucks,the only way to start them in the winter was on gas then switch over to L.P.
Gerald J.
12-07-2004 19:26:53
Are you starting and stopping it by the methods in the 4020 manual?
Gerald J.
Ol Chief
12-07-2004 18:10:14
I have noticed that in cold weather, I am not able to ignite my weed burner torches with an flint type torch igniter. Only an open flame will produce ignition.
Ol Chief
12-07-2004 18:09:22
