Tractor Talk Discussion Forum
John Deere DLTX71 Carberator Question
Roger Reinholdt
12-06-2004 16:29:15
DLTX71 Carberator Question.
All testing is done on level bench.
Float won't hold fuel level when carb mounted to carb main body. With Carb bowl off of carb main body, and bottom nut hole plugged with cork, the float/ neddle valve assembly holds tight. I've replaced float, needle valve and seat. Any Ideas why when carb bowl is back on carb main body, float will not shut off fuel? I have a clear plastic tube in place of carb bowl drain plug to check float level setting and open end is 6" above carb. When bowl is back on main carb body and fuel valve is opened, fuel just flows out of plastic tube.
Roger Reinholdt
12-08-2004 18:06:58
 Re: John Deere DLTX71 Carberator Question in reply to Roger Reinholdt, 12-06-2004 16:29:15
Solved, The bowl vent was plugged causing the fuel to syphon out of the bowl, thus allowing the float to never close the needle valve.
I learned a lot about the passage ways in a DLTX carb. Probably should have read a service manual first. Would have saved a lot of time. Whats a good book or manual on the design and service of the DLTX carb ?
Thanks for everyones help.
34gpa
12-07-2004 13:10:35
If it is plugged it allows it to siphon fuel through. Have had it happen a few times
big jt
12-07-2004 10:22:56
Which drain hole are you hooking the clear tube to? I know this sounds like a stupid question but there are two drains on that carb.
One goes out the side and always has fuel from the tank against it. The other comes out the bottom and is the one to hook to for this test.
Only thing else I can think of is you have something interfering with the float travel when the carb is assembled.
HTH
jt
Weirsdale George
12-07-2004 01:59:28
With the carb off the tractor and turned upside down, can you blow through the fuel inlet fitting? You shouldn't be able to that if everything is sealing properly.
daniel gillespie
12-10-2004 17:29:14
 Re: John Deere DLTX71 Carberator Question in reply to Weirsdale George, 12-07-2004 01:59:28
google robertscarburetor has parts diagrams and free catolog worth the search!
Roger Reinholdt
12-07-2004 03:55:58
No, with the carb upside down, the Needle valve seat combo seems to be holding well.
I've been reading other forum entries, talking about the bowl breather hole being plugged, causing this problem. I don't quite understand why though. If the breather hole is plugged, does this preassurize the bowl, thus not allowing the float to rise and shut off the fuel? Any comments?
