Tractor Talk Discussion Forum
redoing electrical system
country chad
11-27-2004 20:34:17
redoing eletrical system on 1952 john deere B. Got plugs, condenser, coil, points and battery but don"t know what kind of plug wires to get.
apperciate any help my first tractor to redo
Steve - IN
11-28-2004 13:44:39
 Re: redoing electrical system in reply to country chad, 11-27-2004 20:34:17
Chad,
I"d get a wire with stranded copper wire core --
You surely can"t need the radio frquency supression, so why use higher resistance whire.
RAB
11-27-2004 22:56:36
Resistive leads (carbon fibre) would work just as well (better from interference point of view). Depends really whether you want it like original. I have magneto-powered sparks on my tractors, so they must have the copper cored leads without suppressor plug caps. Coil systems are more "forgiving" as long as an electronic system is not installed - as these units will often have so much spark energy that they will destroy the carbon fibre leads in short time.
Regards, RAB
Bob
11-28-2004 08:52:55
 Re: redoing electrical system in reply to RAB, 11-27-2004 22:56:36
I guess you're right, RAB, the interferance from metal-core wires would probably screw up the GPS steering on that old '52 "B".
RAB
11-28-2004 09:31:03
 Re: redoing electrical system in reply to Bob, 11-28-2004 08:52:55
Hi Bob,
Over this side of the pond all the TVs in the street probably start flickering when a mate of mine chugs up the road with his Standard Fordson, with his metal plug wires AND shirt buttons in his plug leads as "helpers" to prevent plug fouling.
In the US I guess you are all so far away from your nearest neighbour you need a GPS to find yourself when you get lost in one of your fields!
I personally prefer the copper leads as "near original" - as long as they are not bright blue or something like that.
Regards, RAB
Bob
11-27-2004 22:11:22
Solid copper core wires are generally recommended for this older stuff. Your local Deere dealer can probably help you, or Brillman, on the 'net.
