Tractor Talk Discussion Forum
Forks lifted pretty good for home made ones
Willy-N
11-25-2004 13:32:28
third party image
Lifted the back end of my 18 ft 1,780 lb Flat Bed Trailer sitting on the Trailer Jack with the Tips of the Forks. The 46" Forks are 3 inch Channel with 2 1/2 X 1/4 inch strap steel welded between the webs underneath. Mark H.
ben uk
11-26-2004 08:55:48
 Re: Forks lifted pretty good for home made ones in reply to Willy-N, 11-25-2004 13:32:28
May i ask, what tractor is that?!
Willy-N
11-26-2004 10:11:44
 Re: Forks lifted pretty good for home made ones in reply to ben uk, 11-26-2004 08:55:48
1969 Massey Ferguson 135 Orchard. Mark H.
ben uk
11-26-2004 10:31:22
 Re: Forks lifted pretty good for home made ones in reply to Willy-N, 11-26-2004 10:11:44
have you got front weight on her?
I was just thinking that with my 135 i wouldnt be able to lift much with the boom before the front lifted i would imagine.
how does she handle it?
Willy-N
11-26-2004 16:53:19
 Re: Forks lifted pretty good for home made ones in reply to ben uk, 11-26-2004 10:31:22
I have 400 lbs of counter weight on the front end. When I tried to lift 3,000+ lbs the front end came up so I put a jack under the hitch to test it for lifting. I know my 135 will lift a 2,000 4x5x8 bale with the counter weight on my other forks. Haven't tested to see what the tractor will lift on the boom but it should be around 1,500+ lbs the boom will lift way more than that. Mark H.
Indydirtfarmer
11-26-2004 04:40:04
Any "real world" testing, as opposed to "labortory testing"? You are lifting a dead load of about (just a guess) 800 or 900LBS on the back end of that trailer. Try a 1500(+) LB round bale, then go bouncing across a rough field at 10 MPH. (over a long time---Maybe a couple hundred bales worth)
Point being; I helped a nieghbor build his own 3 point disc, starting with an old wheel disc. It LOOKED plenty strong. He could pick it up and move it just fine. It even worked well, when he tried to disc his garden.
Then he took it out in the field....
He was discing a 15 acre cornfield. When he got it up to speed, and under a heavy load, the frame just folded like a wet noodle.....
You want the ultimate test? Give it to someone else to test. They won't baby it. They'll hammer the daylights out of it. From what I know about building something like that, You WANT it to be pushed beyond it's limits, just so you will see where those limits are.
I worked for Honda (HRC-raced motorcycles) They WANTED their stuff trashed. The object was to see what broke first, then upgrade that.
No matter what you say or do, someone will try to lift 10 times your "engineered limits". Safe may be 3 times it's intended limit. Practical will be 5 times. Reality will need 10 times that limit....John
Willy-N
11-26-2004 08:19:41
 Re: Forks lifted pretty good for home made ones in reply to Indydirtfarmer, 11-26-2004 04:40:04
If you want stronger ones flip over the forks and weld 4 inch channle to them and they will be twice as stronge and heavy also. But if you want real forks you can buy them for 250-300.00 a pair and just use those instead. Those are what is on my bale carrier. Mark H.
Indydirtfarmer
11-26-2004 08:52:44
 Re: Forks lifted pretty good for home made ones in reply to Willy-N, 11-26-2004 08:19:41
My comments are for your intended selling of your product. You have to realize that MOST buyers won't limit themselves to YOUR intended rating, but will use them for THEIR unlimited loads.
My point is, are you just above your "saftey net" are is the forks limits substancially above that point.
I have 3 sets of TSC "carry-all's" that are wasted. (They were given to me for scrap steel) People buy them, with the understanding that they have a 400LB duty rating, then load them with 1000LBS, breaking them as soon as the tractor starts moving.
Just saying, use caution...Most buyers/users will destroy your product, then throw the blame at you. Test...Test again...Then go back and test once more. Don't set yourself up for a lawsuit. John
paul
11-26-2004 08:05:36
My concern with this "test" is that you are lifiting a dead load, holding it, and _all_ the weight is at the root of the forks. Really didn"t test anything.
I"m with John on this. You need to put some real weight on the tips of the forks, and go make a few laps around the farm in road gear - aim for the gopher holes & dead furrows. See what happens. _That_ will test the forks. :)
A boom pole is generally used a little slower, but a fork lift will be used fast & hard & on the tips. Many folks are going to take a torch & blow a hole in 1 tip, hook wagons to it....
A fork lift gets hammered, you need to test the tip strength under shock (traveling, bouncing) load, not just a dead lift using the fork roots.
As always, don"t mean to be negative, just an opinion. :)
--->Paul
Willy-N
11-26-2004 08:14:35
 Re: Forks lifted pretty good for home made ones in reply to paul, 11-26-2004 08:05:36
If you look at the picture closely you will see the trailer is on the tips. The light load forks you seen sold are made of 3 incn angle iron. These forks were never ment for 1,800 lb bales you need harden steel 4 inch wide 1 1/4 inch thick ones for that like you see on a regular fork lift. Most Cat 1 tractors could not even lift a bale like that in the first place. Yes a bouncing load would increase the loads alot. Like I said befor you can't make something to lift everything posible and all conditions of abuse. Even the best made Honda wrecks when you run it into a wall. Mark H.
paul
11-26-2004 08:49:23
 Re: Forks lifted pretty good for home made ones in reply to Willy-N, 11-26-2004 08:14:35
That is an unfortunate statement for me this morning, had a drizzle at 34 degrees this early morning & I saw a _very_ bad wreck with a pickup T-boning a car into the side of the bridge. I have no idea what type of car it was, not enough left to identify. All I hope is for as few people in that car as possible - can not be good news.....
From the picture you posted, I don't see the forks at all, barely one tractor wheel. Mostly only see the trailer. :) So no idea where your lift point is.
I have a sissors 3pt bale spear, & a heavy duty bale fork for my cat 2 tractors.
Of course I have used the bale fork on both of my cat 1 tractors, lifting 2000# bales. Not good for the tractors, but do I want to dismount the planter or backhoe or snow blower to move 1 round bale????? :) Now 'lifting' is not really a good description, but they did lug the bales around.... Sell me those forks, & they will be hauling 2000# bales all day long - whatever common sense should be..... ;) My brother in law will borrow them & try to lift some iron he thinks is 800# or so, but I know he is off by 1/2.... Then he will pile RR ties on them, and he won't think about it & put as many out on the tip as in close to the tractor. Tractor wouldn't lift that load, but it will hold it up as the arms already were there. Then as he takes off, going to be a load for the end of those forks.....
I'm familiar with the equipment, and how it works, and how it gets abused. I've never compared your stuff to those angle iron carry-all frames. I happen to own 2 of those as well, one I bolted a tractor rock box to for my loader weight box, and the other I bolted 2x8x6' planks to for a nifty wood & many other things hauler platform. I'd not want to try to use those things for a fork lift, angle iron is only stable in 2 dimentions until it's bolted to something - even then it's still stronger in 2 planes than the other planes.....
A static test of fork lifts probably doesn't test much. Forks get a flexing, jarring load as you drive. Your forks (from the other picture where I could see them) look really good - I'm not saying they are weak. Just pointing out you need to actually _test_ them, not just lift something motionless. :) That's all. :)
I know you are getting some flack, & a lot of replies like mine seem negative. But that is what you are here for, to improve on things, right? :) Don't let it get you down. I wouldn't bother replying unless it was interesting or worthwhile..... .
It is possible to re-enforce the root of the forks if you used channel or box, without adding extra metal to the whole length of the fork. They will bend/ break near the root, so you can beef up a foot or 2, save the weight & expense on the rest of the fork. Of course, only if you need to add more to them. They may well be fine as is.
--->Paul
Willy-N
11-26-2004 10:24:37
 Re: Forks lifted pretty good for home made ones in reply to paul, 11-26-2004 08:49:23
third party image
I see your point in what you are saying. Mild steel is not realy intended for jaring loads unless it is way thick and then it can still bend. It needs to be harden steel for that and they will bend but at least the will try to return to there shape if flexed. I am only making this one set up and not going to try to do forks unless they are harden steel ones. I know when I carry our big bales you sure can't drive 10 mph with my tractor if you intend to stop or turn much at all. You need spears to keep it from falling off in a turn at any speed. We get out 1,800 lb bales unloaded with a Case Backhoe and he has a hard time doing it and he can't go fast even with a tractor twice the size of mine. You can see the tips holding the load in this picture. Mark H.
paul
11-26-2004 13:24:16
 Re: Forks lifted pretty good for home made ones in reply to Willy-N, 11-26-2004 10:24:37
Yup, good picture. :)
I run my cat 2 bale forks (3000# rated I believe) on the back of my 7700 - 85 hp tractor most of the time. It has fluid in all 4 tires. I run up & down the road ditches, up and down the tarred road with it, picking up the 5x6 round bales. Can't say I ever went 'slow' with it. :) 7th or 8th gear most of the time. Pretty stable outfit, never lost a bale in 4 years..... This fall I moved 27 straw bales, 12 oats clipping bales. Had to go through a fresh plowed furrow with all of them, kinda land-locked myself. Worked at it from 10:00pn until 2am I think. Sure was a lot of jolting for the tractor, fork, & me, but what ya gonna do? I at least slowed down to 6th & pushed the clutch going through the rough spot. ;)
I really don't like the spear. My experience is fresh bales, the twine unravels & the bale falls apart. Old bales & the spear doesn't like to set in so very well.
I got the sissors bale spear this year, it allows me to just stack bales 2 high, or lift onto a rack or trailer. I figured with the sissors in it & the weight that much farther back, I would need to use the TW-20 on it for weight & stability. But, the 7700 worked it just fine. Again, with the fluiid all around, seems to be a pretty stable rig. I do have lots of hills too.
Need to operate with caution of course, and my bigger tractor & cat 2 setup really doesn't have much to do with your deal. :) Just conversing. :)
--->Paul
Willy-N
11-26-2004 17:03:54
 Re: Forks lifted pretty good for home made ones in reply to paul, 11-26-2004 13:24:16
third party image
I think I could move the round bales on my forks a lot better that I move the big bales with now. My problem is the over hang on the sides of the forks it can tip off on a corner or being tilted sideways and hitting the brakes. These are the Bales I am talking about. This years are allmost a ton each! This is my strong set of forks. Mark H.
paul
11-26-2004 17:54:39
 Re: Forks lifted pretty good for home made ones in reply to Willy-N, 11-26-2004 17:03:54
Yea, a little bitty sablizing spike or 2 up higher would probably help you. Big squares are just starting around here, gaining but not exactly popular yet.
So, good luck in the next 5 1/2 days. ;)
--->Paul
Willy-N
11-26-2004 18:35:18
 Re: Forks lifted pretty good for home made ones in reply to paul, 11-26-2004 17:54:39
Ya I know what you mean 5 1/2 days but I don't think it will fly but you never know. I was thinking of a small spear at the top that comes off when I haul other stuff and small bales. The round bales are not used as much here anymore it seems they all are going to the big square ones. It would be nice if they were the 4x4x6 ones instead! The round ones would settle into the forks nice! Mark H.
Russ Smart
11-25-2004 19:12:08
I made a set for our JD 4600 front end loader a couple of years ago and they are really handy. We always had forks on the farm and now I work in maintenance in a paper mill where we use fork lifts daily for many uses. I made mine out of 4" channel with a heavy gusset inside. They flex a little but have done what I need, for example I stack firewood on pallets and then I can move it around with the tractor.
bo
11-25-2004 19:29:54
 Re: Forks lifted pretty good for home made ones in reply to Russ Smart, 11-25-2004 19:12:08
Russ, how did you attach them to the loader? I've been thinking of making a set for my loader..JD870
sawtooth
11-26-2004 10:09:43
 Re: Forks lifted pretty good for home made ones in reply to bo, 11-25-2004 19:29:54
My son-in-law wanted to put a set of forklift tongs on his Koyker loader. I'm pretty sure he was thinking about mounting them to the bucket. I told him I thought he'd soon have the bucket bent, plus more bulk in the way. At a nearby salvage yard there are some old forklifts. He bought the tongs and mounting plate they hook on from one unit. He took off the bucket and didn't have to do much (weld on brackets to the back of the mounting plate) and he has a handy forklift attachment. A nice plus is you can space the tongs as needed.
paul
11-26-2004 08:20:21
You can make a frame that replaces your bucket. These can get real fancy, with real forged L forks on adjustable rack.... Best type, keeps the load back on the arms, max lift, easiest to manuver/ see/ use. Great with a quick-tach loader bucket setup, lotta work to switch if you have 4 pins to line up....
If you have a strong bucket you can make clamp ons. They slip over the bucket floor & clamp down onto the floor. The fork root goes back to the rear of the buket underneath, and a arm goes over the top with a big set screw to clamp.
If your loader can lift a lot & the bucket floor/ lip is not so strong, the above can bend your bucket. Then there is a similar type, instead of the arm & big set screw, they have a chain that goes up from the fork root over the back of the bucket, down the front, & clamps with a load binder to the top of the fork in front of the loader lip. This places the weight on more points of the loader.
Or you can weld a pipe/ bar on the top of your loader bucket, and hang L forks from it. Works well, but the forks kind of 'dangle', you get no down-pressure/ control.
Versions of all are available for sale, or get out the welder. :)
Also have seen quicktach plate with 3pt frame (or sockets welded into the loader & top of bucket) and people just use 3pt forks, boom pole, etc. on the front of the loader.
--->Paul
bo
11-25-2004 18:39:35
Personally I appreciate the posts. Gives a good analysis and some fine ideas.
Jimmmbooob
11-25-2004 15:43:37
Are you trying to prove something with all the postings about the lifting or is this just for our info? No harm intended just asking the question.
Kansas
11-25-2004 19:49:53
 Re: Forks lifted pretty good for home made ones in reply to Jimmmbooob, 11-25-2004 15:43:37
Its for our info. Besides, this is brand new ground breaking stuff. The only thing I can imagine that was (is) more earth shattering, was when the shuttle when up for the very first time.
Stop and think about it, who would have ever thought about making a tool like that to fit on the 3 point of a tractor.
Willy-N
11-25-2004 16:14:28
Not realy this was for anyone wanting to make a set of forks. I have read posts befor on making a fork lift for your tractor. I allways wonderd what 3" channel steel ones would lift up. Was told channel would bend easy (which it will) used as a fork but for light loads it seems OK. The picture just showed it better. Mark H.
Missouri Boy
11-26-2004 03:09:38
 Re: Forks lifted pretty good for home made ones in reply to Willy-N, 11-25-2004 16:14:28
I made some bale carriers like the Vermeer which goes under the bale and used a 3" channell inside of a 4" channell. Made like a box tube.
Willy-N
11-26-2004 08:16:43
 Re: Forks lifted pretty good for home made ones in reply to Missouri Boy, 11-26-2004 03:09:38
You could flip these and add the 4 inch channle on them and make them like that. Mark H.
brian 1
11-25-2004 20:24:17
I thought you were trying to sell these attachments?
Willy-N
11-25-2004 21:06:36
 Re: Forks lifted pretty good for home made ones in reply to brian 1, 11-25-2004 20:24:17
Yes but it was more of a learning experiance on the reaction of the public and throwing out some ideas along with learning a few things in the process. Mark H.
