Tractor Talk Discussion Forum
John Deer A generator with a 3 wire voltage regula
Xavier
11-15-2004 15:00:18
I'm trying to connect lights to this system. Does the primary wire for the light switch connect directly to the field post on the voltage regulator?
Jon H
11-15-2004 15:25:07
 Re: John Deer A generator with a 3 wire voltage re in reply to Xavier, 11-15-2004 15:00:18
Power for the lighting system should connect to the BAT terminal of the regulator,along with the generator output wire that goes to the ammeter. If you had the old 4 terminal regulator the lighting power wire would connect to the L terminal.
