Tractor Talk Discussion Forum
Talk Radio
Dug
11-14-2004 20:07:50
How can I increase am reception on the radio? I have a cheap boom box with the extendable antenna and can not get any am stations.
Thanks,
Dug
Hermit
11-16-2004 11:32:20
 Re: Talk Radio in reply to Dug, 11-14-2004 20:07:50
Just a couple of things. The external antenna probably isn't the AM antenna. The AM antenna is normally internal on a ferrite rod. If you use the AM radio at night and still can't pick up anything, there's something wrong with the radio itself. If the radio works OK, you can increase the reception by buying or making a tuned, loop resonator and putting it on top of the radio. The resonator is just a length of wire looped around a 10 inch form with a variable capacitor in series. There are plans on the internet.
Kevin (FL)
11-16-2004 05:33:23
Dug,
There is a high sensitivity AM radio made that brings in weak stations--made for remote locations far from any stations. I've been trying to remember the brand to get one too--but it hasn't come to me. I heard about it a few years back and thought about geting one. This was a "stand-alone" AM radio--no FM, no tape, CD, TV etc. I thought maybe one of those survival stores or mountain outfitter companies might sell them. I'll try to locate the brand or someone else might know what I'm talking about.
Ron Anderson
11-15-2004 19:10:16
I had the same trouble as what you are having and I took a car radio 12 volt hooked it to 12 volt battery and connected a car antennae to it. Worked great no noise lots of stations. If it still don't work put car antennae outside building then it will.
greenbeanman
11-15-2004 07:59:00
You kind of answered your question when you stated "cheap radio". To a certain extent you do get what you pay for.
AM stations are typically limited in transmission power unless they have been granted "clear channel" licensing.
You would be taking a chance, but if you want to tinker with our radio and possibly improve the reception or cause harm instead----open the radio to where you can get to the internal workings.
You will note some small square box looking items that have holes with screws in the center of them. The box looking things are about 3/8ths inches square and maybe a �" tall.
With the radio running on battery power, adjust the screws for better reception. Sometimes it works, sometimes you just screw up your radio.
Try it if you dare.
Coloken
11-15-2004 06:45:25
FWIW; if you are using like and auto radio..many have an antenna trimmer to adjust. Pull of the tuner knob and use a long narrow screw driver into the adjustment.
MarkB_MI
11-15-2004 05:35:56
Most radios today have a lousy AM section. Also, the external antenna is probably for FM only.
If the radio has an external AM antenna connector, you can try hooking it up to a piece of wire. It's not that critical how long it is. String the wire across your rafters or some other high spot.
If there's no external AM antenna connector, you can try opening up the radio and locating the AM antenna. It will probably be a brown rod about three-eighths of an inch long, wrapped in fine wire. Take a piece of wire and tape it alongside the antenna (lengthwise with the antenna and crosswise with the antenna windings). You can hook this wire to anything you think might help reception: A wire, piece of steel, whatever. You can also try making a couple of wraps around the antenna with your external antenna wire, but this will affect the tuning and you may start to pick up shortwave stations and other odd stuff.
Your best bet is to either get a high quality AM radio, or spring for XM or Sirius satellite radio.
lucass
11-15-2004 03:07:17
cccrane.com has an am ferrite anenna and some high quality radios for am listeners... i reccomend them,,lucas
