Tractor Talk Discussion Forum
Tractor Hydrolics
David Fickel
11-07-2004 13:52:55
People say that this tractor has 3 remotes, 5, or 6 and so on. What do they mean by this? Is it the individual outlet itself or the 2 outlets together? Liked to know.
Allan in NE
11-07-2004 15:16:06
 Re: Tractor Hydrolics in reply to David Fickel, 11-07-2004 13:52:55
Hi David,
This is one of my tractors equipped with 2 remotes. The bottom port on each remote is the 'lift' and the upper is the 'lower'.
I've seen tractors with as many as 6 remotes hangin' off the back like this.
Allan
third party image
buickanddeere
11-07-2004 14:28:01
Hydraulics!!! A pair of hose ports working together is one remote outlet. Now for loaders and some other applications a supply line will be tapped to run to a remote set of hydraulic controls. That's another whole kettle of fish. The return line will be running right back to the pump suction via the filter housing etc. Some old timers have just on hose connection and use gravity drop. That's still considered a remote outlet.
txblu
11-08-2004 05:53:17
 Re: Tractor Hydrolics in reply to buickanddeere, 11-07-2004 14:28:01
buick, mind dropping by the implement shed this am. Got a question about a possible 1209 swather purchase.
Thanks,
Mark
Drill
11-07-2004 14:23:01
Each remote is one valve and usualy two hose connections(quick couplers). It can be a single acting remote, then would only have one hose, but that is very rare.
