Tractor Talk Discussion Forum
Farmall 300 Wide Front
Tim Janiesch
11-05-2004 07:23:53
Is it possible to put a widefront on a farmall 300 with a narrow front? Any info would be appreciated
Bill46
11-05-2004 09:53:39
 Re: Farmall 300 Wide Front in reply to Tim Janiesch, 11-05-2004 07:23:53
Just be careful to insure you get the long bolt back in the right hole when you drop the small front. One of them is longer than the others. You will not have a full turning radius if you get it in the wrong plave.
paul
11-05-2004 09:46:41
Mine has a factory wide front on it. I'm sure Schwartz made them, as well as others, you can find in the bone yards. The factory one doesn't use the frame rails if I understand the other message right?
--->Paul
Allan in NE
11-05-2004 10:15:06
 Re: Farmall 300 Wide Front in reply to paul, 11-05-2004 09:46:41
Paul,
Doesn't that radius trunnion bolt to the underside of the frame rails? Every one I've ever been around did. Dunno....
Allan
third party image
old
11-05-2004 08:05:43
Yes it takes a way of holding the front end up etc also it is a lot easyer if you have help. I know a place here in Missouri that has 5 or 6 of them $400-650
DL
11-05-2004 17:09:24
 Re: Farmall 300 Wide Front in reply to old, 11-05-2004 08:05:43
Can you provide contact info??? I have a 400 with a wide front that's in pretty bad shape... I figure it'd be cheaper for me to replace the whole front than to try to find all the parts to re-build the one I have! Regards,
DL
old
11-05-2004 18:22:10
 Re: Farmall 300 Wide Front in reply to DL, 11-05-2004 17:09:24
Its a place called brackets in richland Missouri I don't have there number handy right now but if you call infomation they can tell you. I know its 573-765 but thats all
Allan in NE
11-05-2004 07:34:37
Hi Tim,
'Course it is. 4 little bolts and that narrow guy will fall right outta there.
If your 300 had never has never had a wide front before, you will probably have to drill holes in the frame rails to bolt the wide front to. It is really a simple swap. (And smart)
Hope this helps,
Allan
