Tractor Talk Discussion Forum
tire chains
Bob4knee
10-28-2004 21:26:28
Hello all,
I bought a Farmall M last spring, the idea being that I would use it to push snow this winter. I've been meaning to hit the auctions looking for some tire chains, but have not done so, and it's getting to be that time.
What does a total tractor newbie need to know about chains? I'm assuming I'll chain the rear wheels only (it's got a wide front, the guy called it a Schwartz front end, but the tag rivetted to the front end says some other name, I think from Russel Kansas). I don't see enough clearance on the inside of the front wheels for anything at all.
It's got a big old heavy Farmhand loader.(told it's an F10, triangular looking from the side, the tractor fits inside of the loader).
I would rather not mess with filling the tires, thought I'd try chains first and maybe add weights. The tire size is 15.5 x 38, but I have no idea what exactly that means. I'm guessing used chains that fit, say, a 14.9 x 38 would be too narrow? I've got a good inch of tread on the (very old) tires, and no hills whatsoever. This will be my second winter here (eastern South Dakota), we didn't have much snow last year, and I kept it away with a Gravely 2-wheel tractor and a snowblower. (I know the loader's not the best plan, but it's the one I've got for now--the snowblower is still available as needed)
Googling here led me to tirechains.com. I hate to spend 1/4 of what I've got in the tractor and loader so far on chains (but can, if that's what's needed). There's no pavement around, so I guess they'll last a good long while.
Please tell me all I need to know about tire chains on tractors, where to get them, which style I want if I end up going new, what to settle for if I get a deal on used, how to figure out if used chains from another size can be made to (safely) fit, etc. I've got some experience with chains on road vehicles and 2-wheel snow equipment, so I don't need that basic of info, but anything special to tractors will be appreciated.
Thanks,
Bob
Wi Craig
11-01-2004 14:17:33
 Re: tire chains in reply to Bob4knee, 10-28-2004 21:26:28
Here in northern Wisconsin, I have 4 wheel drive and I still use chains and filled tires. Just went to a local Pop and son implement dealer. Bought a set of like new chains for $75, talked him down from $125. $75 should buy you some pretty decent chains that might need some minor repair. I let the air out of the tires when I put them on. When I refill the tires, they are nice and tight, no cables or bungy cords holding them on. Good lick, you find some. Craig
babe
10-30-2004 07:49:07
I don,t live to far from you and as flat as your land is I feel you can get by with just about any chain Go to farm auctions If they are wide enogh you can lenghten.I have a case 1030 with wide tires and on ice it is bad but 4 wheel pickup and wife will get me pulled back . Yes we have been lucky on snow last few years but remember the icy one 4-5 years ago
Mark - IN.
10-29-2004 22:45:18
Thanks for reminding me Bob. It sure is unseasonably warm here in Bristol, IN, tomorrow oughta be a good day to oil them up and hang them to be ready - it'll be too late to do it by the time I need to put them on. I never should've stored them dry like that, but do weigh a ton, and seemed like a good idea at the time. Thanks again for the reminder.
Lou
10-29-2004 04:27:23
Double ring chains work real good in fields and deep snow, twist link chains will work better on hard packed snow and ice and frozen drivesways pavement etc.. They also ride smoother on hard surfaces. I don't know how flat an area you will be on, but if you have any kind of a slope or ditch bank that you will have to back up from after pushing snow off to the side with out chains and a lot of rear weight to offset all of that front end weight you will have problems. On my Oliver 1550 with a loader, my tires are loaded, twist link chains and a 10 ft. back blade, I will still dig and chew at times when I drop The front end in low spot and have to back out, especcially up a grade.
Have fun
MarkB_MI
10-29-2004 04:21:17
If you get the kind of wet snow we get here in Michigan, your M will have a hard time without chains. Wet snow turns to ice when you run over it.
Any used chains you find will probably be the old "ladder" style chains, which don't work so good on tractor tires: they slip between the lugs. Get a set of the "duo-grip" style chains from tirechains.com, and you won't regret it. I did have to cut my chains down a bit; they were too long when new.
leland
10-28-2004 22:41:02
shoot Allen in NE a meaasge he is the top dog on this subject just look for his posts.
