Tractor Talk Discussion Forum
Stuck gears on JD 2955
Henk.
10-28-2004 14:58:52
I had a heavy load of manure behind the tractor and while filling the tank the tractor was parked on a hill and I always had to pull had to get it out of park and now some gears don't work Do you know how to fix it.
Henk
10-28-2004 17:17:48
 Re: Stuck gears on JD 4030 in reply to Henk., 10-28-2004 14:58:52
I posted a message re stuck gears and wrote that it was a 2955 but it should have been 4030 anyway the reply's that I got on the 2955 were not to optimistic.Anyhow for the people that didn't read it this is what happend.
I was loading the manure tank and was parked on a hill and everytime when I had to take it out of park I really had to jurk and pull on the gearshifter and now the High gear won't work does anyone know to fix it
s_ontario
10-28-2004 16:56:19
 Re: Stuck gears on JD 2955 in reply to Henk., 10-28-2004 14:58:52
If its like my 2955 with the hydraulic clutch (like a master brake pump) the reservoir is on left side of steering column look for visable leaks and pray thats your problem ....check the level if its low fill it up to the full mark see how long it will keep the level .
if its the lower side actual part that moves the clutch sell the tractor quick LOL
thats what was wrong with mine $192.00 part yeah but the tractor needs to be split to put it in $1500.. well while its apart might as well put new clucth in $700.00 with plate turned then if your as unlucky as i was they will Hurt the rear seal and oh this won"t show up until after they have put the tractor back together of course so now its split the tractor time again but this time the cab has to come off also.. seal $48.00 total labour $2500
so take it from me fill it up with Brake fluid and trade it off
But it may not be your problem lets Hope ..
Good Luck
leland
10-28-2004 15:09:26
Farm I worked on had a 2590 that would do that what we had to do was use another tractor and push a little and it would pop out of park. but then it finally come down to going to dealer being split and lot's of costly parts replaced. Were's a cab fire when you need one.
