Tractor Talk Discussion Forum
Carb Filling With Gas?????
SJ
10-25-2004 16:12:51
Is there anything you can repair to keep the carb from filling up with gas when you forget to shut it off at the bowl? (Oliver 1550).
Thanks Stan
Can't even use my name
10-25-2004 18:42:38
 Re: Carb Filling With Gas????? in reply to SJ, 10-25-2004 16:12:51
Just had an Oliver 70 do the same thing. Checked needle and seat which looked fine. Played with it for two days before getting the idea to put the float in a can of gas... to my surprise it sank like a rock. No holes but was imploded a bit so it didn't have enough surface to float. May want to check if yours floats. If so then it has to be the needle and seat.
Steve (Magnolia, TX)
10-25-2004 18:22:48
Don't forget to shut it off at the bowl ;-)
But, seriously... I had a similar problem on my 8N (don't laugh), which was corrected when I (finally) got my carburetor fully adjusted (specifically the needle valve/floats). I don't know as it would hold for a week or two, but it'd hold for a couple of days, that way....
HTH
Steve
Allan in NE
10-25-2004 17:32:04
SJ,
Another way to think about that float/needle/seat arrangement is that it pretty much operates just like the plumbing in a toilet tank.
If everything is right in there, it should hold against pressure.
'Bout the only thing a tractor carb can't handle in this respect tho, is the fat lady a singin'. (think about it) :>)
Later,
Allan
Jon H
10-25-2004 16:30:14
If everything in the carb is in good shape and the fuel is clean,they will usually hold against gravity fuel pressure. I have a 4020 JH gas that inspite of repeated checks and adjustments of the carb,still flooded over about 30% of the time. I suspect it is because the fuel lines sat with water in them and have some internal rust that flakes off now and then and causes the float valve to leak. I finally fixed it by installing a 12V fuel lockoff valve just before the carb. This valve is wired to the ignition switch and cuts off the fuel supply as soon as the ignition goes off. A fuel lock is used on dual fuel propane/gasoline setups and are avalible at propane carburation supply houses.
