Tractor Talk Discussion Forum
4010 LP three point lift
Struggling W
10-23-2004 17:12:20
yesterday three point quit, discovered water in oil entered apparently thorough holes in brake pedal boots. Drained system replaced filter worked fine moved 30 large round bales coastal,then today moved one bale would not lift a second. Used Walmart hydraulic oil as it was all that was availble near me. Any quik checks or fixes?
Leland
10-23-2004 20:31:07
 Re: 4010 LP three point lift in reply to Struggling W, 10-23-2004 17:12:20
You better dump that oil fast and get some hydro trans in it or risk spending big$$$ at shop.
Jon H
10-23-2004 17:51:21
Make sure the oil you used is a hydraulic and transmission fluid and meets JD oil specs(J20 if I remember right),and not just a hydraulic lift oil. It must have the right additive package to protect the trans and rearend gears plus work with wet clutches,brakes and your piston type hyd pump.
